Warm-Up Process.
Discussion in 'Gen 2 Prius Fuel Economy' started by sdgeiger, Mar 23, 2005.
  1. sdgeiger
    sdgeiger Junior Member
    97
    Phoenixville, PA
    This may seen like an odd question, but a few times my Prius battery has been in the "Green" area when I turn on my Prius, but yet the engine continues to run when first turned on. This always decreases my average MPH, which is quite annoying.
    Why does the Hybrid do this and is there anyway to override the system so it only warms up if the battery is below "green"?
    -Scott
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It does that b/c that's the way it's programmed. It can be avoided with an EV button.
  3. sdgeiger
    97
    Phoenixville, PA
    I'd prefer to use the spot in the car that the European/Asian Priuses use for an EV button - not the Coastaltech mod that uses the Cruise Control.
    If I can find someone that can install an EV button, I'd go for it in a heartbeat. I won't attempt it on my own.
