Warm weather check engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cooldyood, Mar 3, 2020.
  1. cooldyood
    cooldyood Junior Member
    45
    Wash DC
    Hi lovely people,
    My 2006 Prius with 220k miles has developed an interesting problem. When the weather is even mildly warm (above 50) the check engine light comes on. If it gets colder, the light goes away. This has been going on all winter.
    Any idea what could be going on?
    Thanks, as always!
    49,482
    probably the vapor recovery system.
    But you’ll need to read the trouble codes to be sure
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Get somebody to pull the codes; while the light is ON would be best.
    Totally wild guesses are often worse than useless.
  4. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Need the codes, as already stated. Also, be sure to use a reader that's fluent in Prius. Our cars have a ton of codes that are not programmed into most readers.
    And even if the light is off, a good reader should see it in the history.
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Also, check your oil level.
