Warm weather super green battery action!
Discussion in 'Gen 2 Prius Main Forum' started by sakai, May 7, 2010.
  1. sakai
    sakai New Member
    39
    Charleston, SC
    I have tried searching, but I haven't quite found what I'm looking for. Here goes - I'm mostly a highway commuter, 43 miles each way, with 41 of them on the highway. I'm pokey. Yup, cruise control, 50mph (shift work, and 95% of the time against the heavier flow of traffic).
    What I've noticed owning a Prius so far: temps below 50 degrees (and winter gas probably) seemed to give me tank mpg of 48-52. Warmer spring weather bumps this up to the 52-55mpg range. The start of our Southern warm weather (and a set of Bridgestone Ecopia's ) has my last few tanks at 57-64mpg. All of this makes sense. Now, the question.
    The past few days when leaving work (temps between 85-91 - car is parked under the sun on a hilltop, so it's quite warm), I leave work and get on the highway. The display shows that the ICE is powering the car and charging the battery. OK, seems normal. Except it keeps charging the battery until it's green. And then keeps charging the battery until I reach an incline, where the battery sends power to the drive and keeps me powering through the incline (and for some time after I return to level travel) all the while keeping my mpg in the low 60's. This continued the first time for about 20 miles until I drove through some rain, at which point the magic green battery charge reverted to the normal blue and the mix of charge/use that I am used to seeing. The second time this happened, it continued for almost 35 miles of my drive, until I hit some stop and go traffic and it again reverted back to normal "blue" operation.
    My bar display has shown that my commutes home the past few days have been 75mpg+, which of course makes me suspicious. The change in the operation of the hybrid system makes me suspicious. I'm not exactly complaining, of course, but since I just had a major accident in it... well, I'm wondering - what's going on? Is it simply warm weather effects? Any help ( or links to help) are of course greatly appreciated.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    This does seem strange. What had been damaged in the accident and then repaired?
  3. sakai
    sakai New Member
    39
    Charleston, SC
    My accident was a rear-end collision at highway speeds. I had the hatchback, rear bumper, and rear left side panel replaced. Lots and lots of bodywork to put the car back together, but no frame damage. The body shop (Toyota sent the car to the local Chrysler-Dodge-Mitsu bodyshop) did their thing, and then Toyota had the car for a day to check alignment, hybrid drive et al. Everyone gave the car a thumbs up, and I have to say the first few hundred miles post accident have been just like I remember - great driving.
  4. 2009Prius
    2,705
    510
    63
    I could wave my arm and say that the higher than usual mpg bar graph reading is due to the computer relearning after the dealer resetting it. What I don't understand is why the battery got charged up to green for 20 miles at highway speed of 50 MPH, unless it's all down hill.
    I remember someone posted something similar. Need to do a search.
  5. sakai
    sakai New Member
    39
    Charleston, SC
    And that's the thing - my commute here in SC is very flat with very few gentle, undulating hills. That, and the fact that it's only been on the two hottest days of the year where I have seen this happen. Perhaps I'm just being hyper-sensitive with the car in the first few weeks after getting it put back together. Please let me know if your search finds any older posts - I've tried a few different times without much success.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I have a ~35mile mostly highway commute. In the summer with the grill blocked I could get my 2006's SOC to the green. As the car aged it happened more frequently. It went full green once on I-295 otherwise I'd have to go down a mountain to see that.
    My suspicion is that the toasty battery is showing a higher SOC. If you are using a ScanGauge what is your coolant temp?
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Sure seems likely the numbers are wrong. Not the 70 mpg at 50 mph per se, but the huge jump. Confirm MPG over a two set of fuel tanks.
  8. sakai
    sakai New Member
    39
    Charleston, SC
    JimN - I haven't yet taken the scangauge plunge (that's on the birthday list), so I cannot say. The Prius certainly has been pre-warmed on the two days this has happened, getting a good roasting in the parking lot. Being here in SC, I'm sure I'll be able to confirm with time that it's a temperature related issue, as our summers are rather... warm. :)
  9. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Sakai,
    On flat terrain , without a head or side wind, 75 mpg highway 5 minute mileage bars at 50 to 56 mph (mostly 53) in 70 to 85 degree F humid, but not raining or wet weather, over and over does not suprise me. I think you might have subconcieously found the SHM (Super Highway Point) accellerator position.
    The green bars are suspicious. The car car should run at 6 bars, blue, continuously on flat highway.
  10. sakai
    sakai New Member
    39
    Charleston, SC
    OK, yesterday's commute home from work started at 80F on the temperature reading... and voila! Super Green state of charge for the first 12 miles of the journey, then a return to normal 6-blue action for the rest. Initial internal car temp (as I do drive without the AC and the windows take some time to cool down - not usually until the highway breeze kicks in)?? I'm stumped, frankly. I would have asked the service guys at my local Toyota on Saturday, but I had an AWFUL initial experience just trying to set up an appointment and get prices from them, so that didn't happen.
    Anyone? Anyone?
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It sounds to me like a hot HV battery. Check and see if the battery cooling fan is operating. The battery cooling fan is located in back, and could have been damaged or disconnected during the body work.
    The control system varies the battery limits with temperature. If the battery is hot, it lowers the top limit, so you get to green faster and stay there longer.
    Tom
