Warm weather
Discussion in 'Gen 3 Prius Fuel Economy' started by MPGnutcase, Jun 28, 2014.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    With the warmer weather in Chicago my Prius around town recording 63mpg per tank. Anyone else getting great numbers?
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Upper 70's , Low 80's always provided great results for me... even way back with my 2001 model.
    The engine, battery, and emission-system are all quite happy when it's warm like that, but not hot enough to need A/C.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Interestingly enough though, if I leave my climate control set to "auto", the AC light is always on. Does the Prius prefer to have the AC running to reduce humidity or internal temp for the battery? If this is the case, will it be undesirable if I shut off the AC?
  4. MPGnutcase
    579
    114
    Chicago
    I leave my AC off just make sure rear vent not blocked so air can go over battery
  5. john1701a
    12,755
    5,245
    57
    If you're comfortable, so is the battery.
    When it gets hot & humid, take advantage of the A/C. It's electric, so the penalty isn't that much more than driving with all the windows down.
  6. MPGnutcase
    579
    114
    Chicago
    running around with windows down sunroof open .......................
  7. bisco
    49,500
    gorgeous weather, best summer of my 60 years.
  8. Okinawa
    Okinawa Senior Member
    1,333
    317
    I do just like you do. I like to be comfortable and I think it will be better for the battery. It's costing us very little by doing this.
