Warm, wet, in hurry, P3101
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Mar 11, 2015.
  1. bwilson4web
    16,479
    So this morning, I started the car and quickly shifted into "R". Midway out the drive, ~20 yards, the engine stopped and triangle "!". Turn off and restart, no problem and alarm light remains. At a stop light, the Graham miniscanner found P3101; cleared the code, and; it is time for the Spring oil change the throttle body cleaning.
  2. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Should the throttle body be cleaned each year or just when it throws that code?
    TomK
  3. bwilson4web
    16,479
    Once a year works just fine. It has been about 2-3 years since I did the last cleaning. So whatever causes sticky throttle still exists, just need to pretreat for it.
