Warning FOB changed for 06 prius .
Discussion in 'Gen 2 Prius Main Forum' started by syncmaster, Mar 9, 2006.
  1. syncmaster
    syncmaster Member
    229
    I saw a post on prius-2G forum that the 06 FOB remote part number is 89994-47061 .
    The FOB remote for the 04, 05 prius is 89994-47060 .
    If you are thinking about buying a old used FOB from Ebay for your new 06 prius beware !!
    I believe you can program a 06 FOB to work on the 04, 05 prius.
    but you can't program a 04, 05 FOB to work on the 06 prius.
    Hope this helps,
  2. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Are you sure?
    Where did you get your data from?
    They could have just updated the part number. But that doesn't mean it doesn't work.
    Can you confirm this?
  3. syncmaster
    syncmaster Member
    229
    No I am not sure, I just came across a post on another forum. prius-2G, I think you have to join to read the post here is the post:
    Evidently we're going to have to have the 06 fobs programmed to the
    older cars...
    PN for the SmartKey fob with blank mechanical key is:
    04 89994-47061 (*was* 89994-47060)
    06 89994-47061
    So they updated the fob system, and updated the 06 fobs so they'll work
    with 04-06, but in the meantime the 04-05 fobs won't fully work with the
    06s (as you noted, they only work to start the 06 while in the slot, no
    SK/SS, no buttons).
    I am going to call Toyota TIS and scream bloody murder at them to try to
    get them to swap my 2 extra 89994-47060 fobs for 89994-47061 so I can
    get those 2 and the original 06 fobs programmed to both cars. I'm going
    to be out about $150-60 to do this even if they swap the fobs for free,
    as the 2 new fobs will have to be programmed to each car. Maybe I can
    scream at TIS enough to get it covered under warranty or something, but
    I'm not going to hold my breath.
    One of these days I'm just going to choke down the $3K for a THHT so I
    can do stuff like this on my own. Maybe after the 06 is paid off...
    CJ Mullally wrote:
    > Tom Stangl, VFAQman wrote:
    > >I know it is possible to program a fob to 2 different 04 or 05 Prius,
    > >but after trying to get 3 of my 04 fobs programmed to my 06, the dealer
    > >is telling them that the SmartStart uses a different signal, so the 04
    > >fobs won't work with SmartStart on the 06.
    > >Is there anyone out there with an 06 and an 04-05 that has the fobs
    > >programmed to work with everything, including SmartStart/SmartEntry on
    > >the 06?
    > Unfortunately, my experience with my package 6 '05 smartkeys mirrors
    > your situation. Neither my daughter's package 4 '06 nor my own package
    > 6 '06 will accept the '05 smartkeys. I have tried two dealers and the
    > closest I could come was to get one '05 smartkey registered for
    > Immobilizer use only - none of the buttons work, the doors will not
    > lock/unlock, and the fob must be in the "key slot" to start my '06.
    > Neither dealer charged me for their efforts nor could they understand
    > what was going on because the parts department found only one part
    > number for replacement smartkey fobs.
    > If anyone knows of a work-around, I'm sure others would like to hear
    > about it too.
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    wow. that guy's a high maintenance customer... people like that are the reason customer service jobs SUCK.
    and i hope he posts how well he gets through to the toyota TECHNICAL INFORMATION SYSTEM computer... since it can't exactly talk back...
    pfff.
  5. naterprius
    naterprius Senior Member
    1,843
    Here's the deal: SKS turned out to interfere with Speedpass (mobil and other gas station payment system). Toyota revised the fobs to fix this. This fix is for all Prii 2004 and newer from VIN JTDKB2#U#40011406 and up. If you have a 2004 and its VIN is before JTDKB2#U#40011406, then go to the dealer, tell them it interferes with Speedpass, and tell them to reference EL001-04. They will cover this under warranty as long as you are under 3 year, 36,000 miles. If you don't use Mobil/Exxon/Esso gas stations, it's not a problem.
    Nate
  6. naterprius
    1,843
    I'll also add that if you bought part number 89904–47060 anytime after January 7, 2004, you got part number 89904–47061.
    Also, this change was made very early on in production, so odds are you get the new style SKS fob if you buy a used one.
    Just one more note, SILVER logo fobs are SKS, otherwise they are KEYLESS ONLY. Be careful of this when buying used.
    Nate
  7. syncmaster
    syncmaster Member
    229
    I think there is another change for 06 because from what your saying, a 05 FOB should work on a 06 prius but according to the posts I have read no one has been able to get it to work.
    If anyone has been able to program a 05 FOB on their 06 prius please post here !
  8. naterprius
    1,843
    You think there is a secret, undocumented mystery change that uses the SAME part number? Doubtful. All Prius fobs have been the same since Jan 04.
    What dealership is failing to add another Smart Key?
    Nate
  9. syncmaster
    syncmaster Member
    229
    Read the 3rd post .
    The guy is saying that 04 and 05 FOBs don't work on the 06 Prius.
    According to you the 04 may not work but the 05 should be fine.
  10. drmanny3
    drmanny3 Member
    124
    Orange County, CA
    I posted elsewhere but will post here concerning the smartkey. I purchased a smartkey from someone who had their 05 totaled. I took it in with my other two good keys and the dealership was unable to reprogram the key to work. The best they could do was get it to start the car by placing it in the ignition slot. It will not open doors or work while in your pocket. My 06 is an early car made in 12/05.
    Manny
  11. Springtime
    Springtime Member
    158
    Eastern PA
    <div class='quotetop'>QUOTE(drmanny3 @ Apr 4 2006, 04:20 PM) [snapback]234879[/snapback]</div>
    Manny,
    Just to be sure I understand correctly are you saying you purchased a 2005 FOB with the silver logo and it could not be reprogramed for a 2006?
    I ask this because when I first got my car I did not realize there were two different types of FOBs. The FOB without the silver logo will not work when it is in your pocket - you must have a FOB with the silver logo.
    To clarify your post, are you saying you bought a 2005 FOB with the silver logo and:
    1. it can not be reprogrammed to open the door when you press the button on the FOB;
    2. it can not be reprogrammed to open the door when the FOB is in your pocket?
    If this is what you are saying - the next thing to determine is if this is a damaged FOB or are the new FOBs for the 2006 not really the same as the 2005's.
    I don't think we want to conclude that they are not interchangeable based upon one FOB which might be damaged.
    If you do indeed have a FOB with the silver logo and it could not be reprogramed - we need to have someone else who can try the same thing to rule out the possibility you have a damaged FOB.
    Springtime
