WARNING LIGHT FOR HYBRID BATTERY FAN FAILURE???
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Eric "v", Jun 13, 2015.
  1. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Do we have a warning light for fan failure for the hybrid battery?
    This is crucial B/C a cooling fan failure here is death for the battery. An new battery is 'expensive as hell.
  2. PriusInParadise
    180
    91
    Hawaii
    There is no separate light for the HV battery fan or a battery cooling system fault.
    All powertrain faults use the same Malfunction Indicator Lights / warning lights:
    Hybrid system warning light, the car with an exclamation point through it, and
    Check engine light, an engine with the word "Check" below it.
    51,155
    and then you will have a trouble code logged with the detail. but there is no warning for a clogged fan, so i check mine once a month.
  4. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    bisco,
    How do you check your fan for clogging? Is it very involved to get at it?
    I have a steering column-mounted ScanGuage II which weill tell me what engine code a "Check Engine" light is sending and then I refer to a printout from the dealer's service department to tell me what that code means.
  5. bisco
    51,155
    you can set your scan gauge to monitor your battery temp, i don't have one, but there are threads here. you can access the fan and vent tunnel through the rear when you take everything out to expose the battery. it's a one or two hour job. there's a youtube on the gen II, but the III is similar, and shouldn't be too difficult to figure out.
  6. Mendel Leisk
    40,584
    Is the plug in battery actually a pair, big, accessible towards rear of hatch area? Reg Prius battery is single, smaller gerbil cage style, beside passenger side end of hybrid battery, takes some parts removal to access.
  7. bisco
    51,155
    plug in must be more complicated with 2 inlets.
  8. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I see that there is a TSB on "clogged hybrid battery fan" so I'll check with my dealer on that one.
    Also I'll see if I can access my hybrid battery temps via my ScanGuage II. Thanks for that tip. I'm hoping I can so I can put in my default display to keep my eye on it. I'll ask my service dep't. for the hybrid battery "safe zone" temperature range so I know what I'm looking at on the ScanGuage II.
  9. Mendel Leisk
    40,584
    There is an X-Gauge (ScanGauge add on) for each of the three hybrid battery sensors, on regular Prius. The middle (#2) sensor tends to run highest temp. There's another X-Gauge for fan speed. Hopefully works on v, or there's another that will.
    I found it a bit tricky adding X-Gauge. There's a decent YouTube on it, helps.
    The highest temps I've seen are around 46C, and fan speed 4 (out of 6 I think).
    I'd suggest a DIY dig down to your fan. It'll likely involve some pull up of the hatch floor, and removal of the inlet grill. Only do what you have to: if it's similar to reg Prius complete removal is no necessary for cleaning.
