Warning light, problem on touchscreen
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Diane Riley, Jan 13, 2021.
  1. Diane Riley
    Diane Riley New Member
    Cobbs creek, va
    I ran over a deer last week, it punctured a hole in a piece of the coolant overflow tank. We replaced the piece that was broken but now the air doesn't get warm and the red triangle comes on and it flashes problem on the screen. it showed the coolant symbol with problem the last time it came on. Also the check engine light is still on. It came on when I hit the deer.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    FYI, you're moderated until you have posted five (5) times.
    Best to read the OBD2 codes (DTCs) with a compatible scanner, then post the results here for additional guidance.
    Did you bleed the air out of the coolant system?
    Have you checked the coolant level in the radiator itself?
    Is the water pump belt attached and turning the water pump?
    Below is an image that may help you locate the radiator and cap
    JC91006 likes this.
