Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jared, Apr 26, 2013.
  1. Jared
    Jared Member
    209
    Long Island
    I have a 2005 Prius with 135k miles. Yesterday the red exclamation light came on and also the hybrid system warning light. I shut the car off and it came on again. The third time the car started normally and it is driving normally today with no warnings. Does this sound like the 12 volt battery? It is original.
    Thanks.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Yes it does. It needed replacement a while ago. It has lasted its expected life and then some.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    You should use a code scanner to see what DTCs are stored, if any. You wouldn't want to miss something if it's not only the 12V battery and you end up getting stranded somewhere miles from home.
  4. Jared
    Jared Member
    209
    Long Island
    Thanks. So far it is ok. If no more warnings show up then I will wait for the next oil change and have the codes checked.
  5. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    It is now set to put you down anytime and anywhere. Best to replace the 12V at your choice of time and place.
    JMD and Britprius like this.
  6. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Yes. Today all the warning lights came back on and my wife could not shut the car down or move it. This was 30 miles from home. I arranged to have it towed. Luckily, I hit the power button twice and it did go off. I then was able to drive to the dealer. The car died when I shut it off right at the dealer. They had to jump start it onto the hoist. It was just the battery. Quite expensive - the battery alone was $230.00. Next time I will take no chances if I see a warning light.
    JMD likes this.
  7. SteveLee
    645
    180
    North Carolina
    I
    Sorry to hear it let your wife down. Good you were able to get it towed. Bad it was towed. Lots of reports of damage from being towed by people who don't know what their doing. Good you got the battery replaced. Bad it costs so much for the genuine "special" battery for this car. A little late now but there are much less expensive alternatives. Check out the thread Fitting mobility 12volt AGM battery. | PriusChat
