warning lights all go on and car quits
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jtm3djad, Nov 21, 2007.
  1. Jtm3djad
    Jtm3djad Junior Member
    Houston
    As I'm driving, all of the sudden the warning lights go on; I had to drive about two blocks to pull off the road, but then was able to pull off, but the power was lessening. The power is totaly off, and when the power button is pushed, no response. Now what?
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    In an '08? If you didn't run out of gas and/or drain the 12V
    battery, the dealer should be right there to help... get them to
    pull codes and see what happened.
    _H*
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Sounds like you ran out of gas...if that's a possibility then add gas and try again. If that is not possible thene have it towed to the dealer and fixed.
    Please updated your profile so we know what car you have. Letting us know how long you've had the car (miles on ODO) and a few more details goes a long way to helping you, otherwise you'll get a ton of random guesses of little value.
    Knowing what you did after the car died would be nice too...
  4. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    <div class='quotetop'>QUOTE(efusco @ Nov 21 2007, 08:57 AM) [snapback]542362[/snapback]</div>
    Agree to updating profile, also package 9 doesnt exist on a 2008. But your suggestion to add gas assumes that the vehicle and driver are still in the same spot some 6 hours after his post.
  5. czyfrme
    czyfrme Junior Member
    34
    25
    So. Illinois
    2001 Prius
    maybe the accelerator pedal is bad? i was having the same symptoms and that was the culprit. ~$500 fix. :(
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I believe the accelerator pedal problem was only on the 01-03 Prius.
  7. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    Say kadinZ, if "American" had delivered on these types of high mpg car in the first place, then most of us douche bags would have probably bought American.
    By the way, I feel the luuuv.
