Warning lights all over, and wacky readings from my code reader
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DirkusMaximus, Nov 30, 2020.
  1. DirkusMaximus
    DirkusMaximus New Member
    North Carolina
    Hello, all. One of the three prii in my fleet is being a bit of a problem child.
    2009 model, basically stole it from a guy for $1500. 158k miles.
    Currently getting the Red Triangle, “BRAKE”, ABS, VSC, and ( ! ).
    Codes include U1029 (lost comms with brake system control module), U0073 (control module communication bus off) U0123, U0124, U0126 (lost comms with yaw rate/lateral acceleration/steering angle sensors, respectively) and other similar indications. I also got C1310 at one point, and was checking the inverter cooling system (no visible leaks, plenty of fluid, good turbulence in the tank so the pumps ok) when I noticed the crazy traces on the inverter temps and B+ voltage levels on my code reader while driving around the block at about 25mph. See the attached image for reference. Pretty sure the inverter wasn’t heating and cooling itself between 150° and 0° in an instant like that, so obviously a garbage reading.
    To me, this all points to a crappy connector somewhere. The question is, WHERE? Can anyone point me in the right direction?
    I am suspicious of the brake power module under the trunk. My daughter left a leaking jug of coolant in the trunk and I just had to drain about 1.5” of coolant from under/around the battery last week. :mad:
    I’m not afraid to dig into this thing, and I’m pretty OK with hand tools. I’ve already pulled the dash apart and fixed the bum cap on the dash display board on this car. Don’t be afraid to use technical jargon. Hit me with whatever you’ve got.
  2. strawbrad
    953
    999
    The U codes match what I have seen caused by a faulty skid control computer. You will need Techstream to calibrate a replacement computer. It's possible to plug in a replacement computer without removing the original. That's a cheap option for a quick test. The ABS (skid control) computer is located just above the gas pedal. It's top mounting nut is just below the speedometer. It's possible to get this nut from below, but it's not easy.
    DirkusMaximus and SFO like this.
  3. DirkusMaximus
    North Carolina
    Would this also cause the wacky readings from the cooling system, or is there a possibility of there being multiple issues here? I mean, that’s always a possibility I suppose, but could a bad connection somewhere else cause both symptom sets at the same time or is this definitely just at that one computer?
    You underestimate my power, Obi-Wan! :LOL: You should see some of the spaces I have to get in and out of at work on a daily basis. It’s a wonder I don’t have back and neck issues (yet).
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Before you spend ANY time or money on anything else.............
    Make absolutely, positively sure that the 12 V battery and it's main connections are good.
  5. DirkusMaximus
    North Carolina
    Did that. Replaced with a new yellow top as well. All connections are solid.
  6. strawbrad
    953
    999
    Challenge Accepted!
    To get to that top nut use a deep 10mm socket with 1/4" drive. 3/8" drive is too big for the small space. After the 10mm socket you need a 1/4" drive u-joint and then about a 2 ft extension. I wrap the u-joint with a turn of masking tape to give it a little resistance. This makes it possible to direct the socket onto the nut. You will also need a flashlight to see the nut.
    Sit down on a short stool next to the drivers door and lean in under the dash. When your right ear is almost touching the gas pedal your in the right position. You may also notice the doors rocker panel digging into your side.
    I would ignore the inverter readings for now. The C1310 means one computer is getting an error message from another. All the U codes point to the ABS computer. I have replaced five of them over the years.
    Enjoy
    DirkusMaximus likes this.
  7. DirkusMaximus
    North Carolina
    Just to be clear, you’re taking about the main ECU (green highlight) and the three nuts on firewall studs, including the one in a nice cozy spot up top (red highlights), correct?
    660F61F0-8DCF-4E70-8E21-3B97A88F51F8.jpeg C0A08DB5-9C8B-40AF-B330-7BCFE9D53405.jpeg
  8. strawbrad
    953
    999
    That looks like the right computer. It's the one just above the gas pedal. Yes, there are three nuts on studs holding it in place.
    Use http://www.car-part.com to find a computer in a local junkyard.
  9. DirkusMaximus
    North Carolina
    Hmm. I’ll need to make sure my diagnostic rig can rewrite the VIN, reset the immobilizer, and whatever else needs to happen there. I’m pretty sure it’ll do the VIN reprogram, but I’ll have to check on the other items. You mentioned calibrating something as well?
    What about these guys? They claim they’ll preprogram your VIN for you and send you an immobilizer hack tool as well to make it “plug and play”for $179. Might be worth it versus me smoke-checking an ECU trying to figure out the ins and outs of reprogramming it.
    2009 Toyota Prius 1.5L - ECM ECU PCM | 89661-47250 | Flagship One
  10. strawbrad
    953
    999
  11. DirkusMaximus
    North Carolina
    Glad I asked.
    Nope, I’ve got a Zurich ZRPRO tablet. It’s pretty capable, but there’s not a lot of info in the manual, and a lot of chingrish in the menus
    I found this: but that’s it so far. F291DDB8-C67F-4711-8961-58A1B2219CBC.jpeg
  12. DirkusMaximus
    North Carolina
    Maybe it can zero those after all...
  13. sam spade 2
    7,035
    2,788
    2017 Prius c
    Did you fully charge and test the new battery ?
    The yellow tops have had a problem with "infant mortality" at times.
    Then.....what exactly do you mean by "solid" ?
    You can't know if the connections are good just by tugging on them to be sure they are tight.
    When you have electrical trouble, a multi-meter is an invaluable tool.
  14. strawbrad
    953
    999
    Look to see if your scanner can do a Linear Valve Value Initialization.
  15. DirkusMaximus
    North Carolina
    12.78v across the lugs. Cleaned the terminals. Solid 12.76v at the power socket up front, indicating good ground and power in acc mode, with nominal voltage drop.
  16. DirkusMaximus
    North Carolina
    I’ll look into it tonight and see what it’s got. I seem to remember something that looked like that, I’ll double check when I get home. This ZRPRO computer is actually pretty surprisingly decent for a Harbor Freight tool.
  17. DirkusMaximus
    North Carolina
    Yep! It can do that too.
  18. DirkusMaximus
    North Carolina
    So, a neat thing happened after resetting the existing “bad” skid computer and doing the zero procedure on everything as a practice run before buying a skid computer and using the diagnostic tablet “in anger” with it.
    Nothing. As in no more errors. No more warning lights. We’ve driven the hell out of it for two days, over 150 miles, no trouble.
    I can only assume here was some kind of calibration memory issue. At this point, I’m still considering buying a skid computer just because memory cell failures don’t just go away. (case in point: Tesla’s recent woes with their MCU’s) But for now... :shrug:
    strawbrad likes this.
  19. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    Sometimes things get out of spec and just need to be recalibrated. I wouldn't worry unless it goes out again.
  20. doctorman
    doctorman Member
    203
    34
    NY 11020
    did your problem come back or that was it..?
