Warning lights came on while traveling.
Discussion in 'Generation 1 Prius Discussion' started by shane1969, Aug 11, 2012.
  1. shane1969
    shane1969 New Member
    2002 Prius
    I was driving at 60 mph and the master warning light came on can anyone give me any help with what may have caused this.
    bwilson4web likes this.
  2. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    The most common thing is the inverter water pump. You can look and see if the coolant in the inverter is moving around. I'm sure there are many threads on how to do this. Other then that we will need diagnostic codes.
  3. Patrick Wong
    18,200
    6,471
    What other warning lights appeared besides the red triangle master warning light?
    If that is the only light that came on, then it is hard to say what the problem is and it is doubtful that any DTC were logged. I suggest you start by checking all engine compartment fluid levels as well as your fuel tank level.
  4. jhknight
    jhknight Junior Member
    74
    south central Minnesota
    2002 Prius
    I used to get the master warning light from a loose connection in the wiring harness at the main battery. jiggling the wires would get rid of the light. Dealer did something to tighten that connection and it hasn't happened in a long time.
