Warning Lights-Loose Gas cap?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RXY CAT, Oct 13, 2009.
  1. RXY CAT
    RXY CAT New Member
    2006 Prius w/75,000 on it with regular service
    Filled up with gas Sunday night, drove a short distance, noticed these warning icons were lit up-master warning light, (O) w/! inside--brake, VSC, Check engine and Hybrid system.
    Pulled over, gas cap not tight, so tightened that. Stopped 1 hr for dinner--had to eat anyway. Came back, same lights on. Drove 2 miles home, car seemed to drive fine.
    Got up early on my day off, called dealership, they said it probably was the loose gas cap and to drive it for 3 trips of some distance and it should be fine. Drove 5 miles that day, no change
    Tuesday morning, only the Master warning, check engine and hybrid sytem lights were on, drove 35 each way to work, car seemed to run fine, but on the trip home all the lights lit up again and then a fan sound came from the vent on the right rear passenger side--battery fan?
    Ask me a cat health question and I could answer it, this I feel means a trip to the dealership for me but I'd like to go in armed with some info.
    Thanks in advance, Teri
  2. Patrick Wong
    18,200
    6,492
    Hi Teri,
    Yes, you should visit the Toyota dealer soon. If the gas cap was loose, the check engine light would come on but the brake, VSC and hybrid system lights should not. Maybe the inverter coolant pump has failed. Good luck.
  3. RXY CAT
    RXY CAT New Member
    Have an 8:30am appt tomorrow...I'll need luck,thanks!
  4. doctorman
    doctorman Member
    209
    35
    NY 11020
    wow Prius gets really scary if you don't have full warranty on it!!
  5. RXY CAT
    RXY CAT New Member
    Sorry for the late update to my post about the warning lights...turned out it was the "main battery" failure and they replaced it under warrently--whew!!
  6. triumph1
    triumph1 Member
    275
    Would that be traction or auxiliary?
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Traction.
