Warning lights - What do they mean?
Discussion in 'Gen 2 Prius Main Forum' started by Yves, Apr 2, 2018.
  1. Yves
    Yves Junior Member
    Toronto
    Hi there, and thanks in advance for any help anyone can offer.
    I've got a 2007 Prius with just under 100,000km. This weekend, 4 warning lights came on - 3 on the dash, and 1 on the main interface. They are:
    On the dash:
    1. Large exclamation mark inside a triangle
    2. Smaller exclamation mark inside brackets
    3. Check engine symbol
    On the interface:
    4. A weird shaped orange tear drop with a vertical line through it.
    I haven't drive it around, but it starts no problem. Interestingly, I hooked up a code-reader, got a green light from it, and a cryptic message. Specifically, the code reader displayed the following message: No Powertrain DTCs or Freeze Frame Data is presently stored in vehicle's computer.
    I don't know what this message is, and feel no relief from it :)
    Below are the pictures of the warning lights and code message.
    Any help would be greatly appreciated!!
  2. Yves
    Yves Junior Member
    Toronto
    A bit more background info:
    - I've never had any of these warnings before
    - I just had an oil change, not sure if the system was reset to register the oil change
  3. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    The lights mean you have a serious system fault, one or more ABS fault codes, one or more powertrain faults and one or more HV System faults.
    The fact your scanner says you do not read any powertrain faults and does not see any other ECUs, means your scanner is not updated with Prius PIDs (or data files). Some models of Innova scanners can read all Prius ECUs, maybe yours is not one of them or it needs updating.
    In order to diagnose further, you need to read all ECUs to get all codes and report them back here.
    jerrymildred likes this.
  4. Prodigyplace
    12,407
    11,682
    Central Virginia
    Does this car have the original 12 volt battery? If its voltage is too low some ECUs can get confused and produce strange trouble codes.
    Checking the battery and replacing if marginal is not a very expense process.
    Once it is verified as good then you need trouble codes read.
    EDIT: Oh No! I'm turning into @bisco ! :eek:
    #4 Prodigyplace, Apr 2, 2018
    pilotgrrl, wfolta, scona and 2 others like this.
  5. bisco
    51,154
    oil change monkeys often leave the lights and stereo on, draining an already weak battery.;)
    kenoarto likes this.
  6. Yves
    Yves Junior Member
    Toronto
    Hi guys - thanks very much for the feedback.
    Prodigyplace - yes, the 12v battery is low, and I can't confirm if it's the original, but based on the kms being so low I would assume so. In the 'Vehicle Signal Check Mode', it says I'm running at 11.4-11.5v, which youtube says makes it in need of changing - Toyota dealer didnt make a big deal of this.
    I took the car in to get hte codes read and was told that I needed a new Hybrid battery based on having the following to code: P3000 & P0A80. They explained that of the 18 cells, one is reading lower than the rest at 15.2V - apparently the differential between that one (cell 16) and hte others is really serious.
    I asked if there was a connection between the low auxiliary battery and the current issues and was told no. I asked if the car would give me any warnings when the 12v was getting low and was told no. They were in agreement that all this seemed odd considering the low kms on the car (95k).
    Interestingly, they offered to disconnect the main battery and leave it sitting overnight, then reconnect it in the morning...the mechanic said that this helps 'equalize' the cells, and swore that he'd seen positive results from this. I said this sounded very bandaid-ish, but as there was no charge for this, agreed to it.
    They removed the warnings from the dash and drove the car out...so if you didnt know what was going on, you'd have no way of knowing. They told me there's no way of knowing how much hybrid battery i had left - could be days or months.
    Not sure what to think and don't have much confidence, but below is an image of the diagnostic, and I'll follow up tomorrow with the 'equalizing' results. For the record, I was told that a new battery would be $2900 + 5hrs @$125 to install. Extremely unlikely that I'll put 4K into an 11yo car...even if it's only got 95km on it. Any comments or advice is more than welcome - thanks!!
  7. Prodigyplace
    12,407
    11,682
    Central Virginia
    @Tideland Prius or @Mendel Leisk any ideas?
    I wonder what it would cost for one of @2k1Toaster 's kits shipped to Canada with whatever duty would be involved. I know he has said the bulk of his charges are for shipping from China & within the US. It would still need to be installed, though.
    There should be some good independent Hybrid shops in the Toronto area.
  8. HBS
    HBS Member
    74
    56
    MO
    So did you install a good 12v battery? It's a little odd that a Toyota mechanic thinks disconnecting the main battery and letting it sit overnight would help anything? Did you think they were talking about the hybrid battery or the 12v battery?
    pilotgrrl and wfolta like this.
