Warning Lights
Discussion in 'Knowledge Base Articles Discussion' started by Houston, Aug 6, 2005.
  1. Houston
    Houston New Member
    37
    Saltspring Island British Columbia
    [align=justify][marq=left]
    The Immobilizer icon flashes whenever the fob is removed. Is this normal and, if so, to what purpose? It would seem to be a ineffective deterant unless the potential thief had a owners manual handy to explain what the signal meant.
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    When you say that you remove the fob, is this because you're exiting the car? Do you have Smart-Key?
    Personally, I have never put the fob in the dash.
    Is the Immobilizer icon the key with the exclamation point through it? I would think that any sentient human would see that thing flash and know that it's a key and there's an exclamation point. That probably means that it's locked and alarmed.
    On the other hand, I had a friend who wired an LED to flash every three seconds. He poked it through his dashboard and it looked identical to the flashing LEDs of legitimate car alarms.
  3. Houston
    Houston New Member
    37
    I
    I do not have a "Smart Key" therefore the fob is out of the dash slot whenever I leave the car. The icon is a car with a key through it. No exclamation point. Unless our thief had eyes like a hawk and was indeed a sentient human being, the icon is merely a flashing orange light and not particularly threatening. To top it off my car is not equipped with an alarm system!!
  4. removeum
    removeum Member
    407
    El Paso, TX
    8) Your car may not have an alarm. However, it does have an engine imoblizer.
    Ben
  5. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Actually, it does have the alarm, just that you didn't pay for it, so it is turned off. It can be turned on easily using the scanner.
