Warning lights!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Loanshark, May 12, 2016.
  1. Loanshark
    Loanshark New Member
    Indianapolis
    The triangle, brake, vsc, CEL...
    The brake and the vsc shut off after a short drive. Car seems to drive fine.
    What are the recommended first steps for DIYers? Don't have a mini vci yet.
    52,390
    check your 12 volt health.
  3. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    1) Per bisco, confirm 12V health.
    2) Read codes. Code reading options in my sig.
  4. FazilHussein
    FazilHussein Member
    71
    36
    Perth, Ontario, Canada
    Check your tire pressure in all four corners; I had one down to 22 lbs, gave me the same lights you indicate.
    Faz
