Warning: NEVER head in the garage!
Discussion in 'Prime Main Forum (2017-2022)' started by CaliforniaPrius, Dec 23, 2016.
  1. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    2nd day with the car. Took it for a spin. This time, head in the garage as it was raining hard. Pulled up the trunk, got my stuff and later opened the garage door...... Bang! Here's the result:
    It turns out that the trunk cover is way too high. Dangerously close to the ceiling such that the garage door will scratch the cover when the door is open.
    So glad I stopped it immediately otherwise the light fixture could break. That's actually the highest point.
    Never head in the garage!
    Dragon Rider, svrider and 'LectroFuel like this.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    700
    274
    Maine
    That is just your garage design. Not every garage design.
    JeffMN, Zythryn, joelp and 1 other person like this.
  3. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Ohhh, I would be soooo mad at myself! I'm still careful of opening my trunk in my garage even though I know it'll never hit.
    Insirt and svrider like this.
  4. Mendel Leisk
    38,649
    I've wrapped our garage door opener's trailing arm with foam insulation, after maybe the third incident: opening or closing garage door with the hatch up. Typically the door derails, which helps.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,023
    Westminster, Colorado
    It never occurred to me to let the garage door move while I have the hatch open. Thus, in 18 years of living here, 13 with my Prius, I never have.
    JeffMN, xliderider, fuzzy1 and 3 others like this.
  6. Prius Maximus
    Prius Maximus Senior Member
    935
    780
    Northeastern IL
    One of the first things I do with any new vehicle is check clearances in the garage. Length, width, and opening the hatch in several places: inside underneath the light fixture, under the garage door bottom edge when the door is up, and under the eaves. I learned to do this long ago when I backed my truck up to the garage with the bed cover door open and ran it into the eaves. :eek:
    Don't forget that they added 4" to the car and that is in the hatch, so the hatch will be higher open than prior prii.
    mmmodem likes this.
  7. shakya
    shakya New Member
    sri lanka
    2014 Aqua
    Do a cut and polish... u may be lucky.. if the paint is scratched no option.. hv to paint it
    SM-T705 using PriusChat mobile app
    Andyprius1 likes this.
  8. jmarkd7
    jmarkd7 Member
    Virginia
    2018 Prius Prime
    Sorry that happened!
    One way to prevent this is to keep your garage so full of stuff that you can't fit a car in there ;)
    RobH, milkman44, MrMischief and 6 others like this.
  9. bisco
    49,382
    yep, been there done that. more times than i care to remember. i've foamed everything that could cause damage.
    wasn't this an issue on your last prius?
    some people install shorter struts or a bungee to keep the hatch from opening too high.
    #9 bisco, Dec 24, 2016
    Prius Maximus likes this.
  10. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Sorry to see that happened
  11. inferno
    inferno Senior Member
    1,072
    405
    This has happened with all our Gen 3s and I'm afraid to put the prime in the garage. Don't tell the kids to just close the garage door, we've had the door pull the trunk up and down trying to close before giving up! Horrifying. Ok, tell them, but make sure they know about the trunk lol. I'd like to think I've learned my lesson and will put some padding up there. That Prime hatch also seems to open way higher than the Gen 3!
  12. Civic4982
    Civic4982 Member
    46
    40
    Bummer. Mine opens okay with garage door closed but will definitely hit it with it open.
    To open it up sometimes I'll put a cloth sheet over it and slowly open it up to rest it gently as it nears impact.
    iPhone ?
  13. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    Good info to know. Sorry for your loss.
  14. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Sorry to hear your damage to your new baby. OUCH! Both of my cars have powered hatches with settable height memory so we don't have to worry about this. Cheap foam pipe insulation attached to the garage door at contact points is a very popular solution.
  15. Lee Jay
    5,850
    4,023
    Could someone measure the height to the highest place with the hatch open?
  16. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    Almost hits my garage door. Opens up too high, in my opinion.
    MrMischief likes this.
  17. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  18. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    I noticed that immediately too when I parked my car in the garage and noticed how high the trunk opens. The trailing arm would definitely scratch the trunk for sure. Either you wait until the door completely closes or opens to open the trunk to be safe, or just park reverse as suggested.
  19. Mendel Leisk
    38,649
    You've got to watch in any covered parking lot too. Easy to forget.
  20. fuzzy1
    10,159
    26 years since I installed an opener on my garage door, all those years with various hatchbacks, and I never have either.
    For me, not moving the garage door while the hatch is open, is easier and safer than backing into the garage.
