Warning on shut down - Check Smart Key System
Discussion in 'Prius c Technical Discussion' started by E M Atwater, Dec 30, 2016.
  1. E M Atwater
    E M Atwater New Member
    Washington State, USA
    Started getting this warning message every time I shut the car off. Was in my dealership for an oil change today, and they were clueless as to what it meant. They changed the battery on my fob, which did nothing. Technicians said they'd "never seen that one before," and I can't find anything relevant online either - Surely someone else has experienced this?!
  2. Mendel Leisk
    42,331
    If there's a warning there should be codes?
    52,831
    check your 12v i suppose. i don't understand dealers. if they can't figure something out, don't they have a hotline to toyota?
  4. StockLX
    StockLX Junior Member
    16
    Halifax, NS
    Got this warning today on my C as well. however it seems to have gone away for the time being.
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    The Prius C manual indicates that this could be a problem either with the smart key or with the steering wheel lock system.
    Have you tried switching to the other smart key to see if it gives the same message?
  6. bisco
    52,831
    sounds like a loose connection.
