Warning when getting oil changed by dealer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pederson80, May 26, 2011.
  1. pederson80
    pederson80 New Member
    Cambridge, Wi
    I went to a dealer to get my oil changed last week and when I was under my car installing my block heater I found that part of the plastic shield was cut off. :( The access panel for the oil pan and drain plug was cut off completely! I was shocked! :eek: I called them back and told them I needed that to keep my ICE warm in the winter. They are ordering a replacement at no extra charge.
    :mod:So if you get your oil changed from the dealer make sure to check to make sure you have a full plastic shield underneath the engine.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There is apparently a TSB on that cover. They are suppose to replace it. In your case they just cut it off... lol. How sad.
  3. jamesa53
    jamesa53 New Member
    74
    Indiana
    Deleted post
  4. Mendel Leisk
    38,644
    Is this the first time you've looked at the underside? Also: how many oil changes have been done, and did the dealer do them all?
    I can't see them intentionally just cutting it off. More likely scenario: it became partially broken at the hinge, after several openings, and they decided to cut through the remaining portion of connection. Still, not good.
    There's several threads here regarding the weakness of this hinged door.
  5. alevinemi
    alevinemi Junior Member
    99
    17
    Indianapolis
    2014 Prius v wagon
    My Prius was 100% dealer serviced by the previous owner. I've changed the oil many times, and although I wasn't really looking for it, I didn't notice any kind of shield obstructing my access.
    Can you give me a clue as to what this is, where it is located (perhaps a pic or schematic)? Does it even apply to a Gen 2?
  6. Mendel Leisk
    38,644
    Not sure but I don't think there is a shield on gen 2.
  7. pederson80
    Cambridge, Wi
    I owned a gen II before and it didn't have the shield I am referring to.
  8. pederson80
    Cambridge, Wi
    I have looked at the underside before. I didn't notice anything wrong with the hinge when I installed my block heater.
    I just bought the car last October and changed the oil twice at the same dealer. I did notice they broke one of those clips which holds it in place.
    My only guess is that it annoyed them in some way. Like you said there are several threads on it being very weak. Maybe when I get my new shield I will buy some metal hinges to hold it in place... or use military grade duct tape:)
  9. pederson80
    Cambridge, Wi
    I'm not familiar with that TSB. Thanks for the heads up.
    Do you know how they are suppose to replace it?
    They told me they would replace it with another one.
    Is it supposed to be a redesigned cover?
  10. LeadingEdgeBoomer
    289
    29
    New Mexico
    More info about this TSB please!
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I don't have details but it was mentioned in one of the other threads. I was meaning to login into toyotaowners.com and see if it was applied to my VIN and or I will stop by the dealer and see what they say.
    For what it is worth though, my cover is still in great shape after three changes.
    [edit] - toyotaowners.com does not display TSBs it appears. Will try edmunds.com.
  12. Den49
    Den49 Member
    498
    268
    Maryland
  13. pederson80
    Cambridge, Wi
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Doesn't matter if it was a process that lead them to cutting off a partially broken hinge or not...you don't remove parts of someones car for your own convenience, partially broken or not, especially when there are service bulletins from Toyota about how to handle it. I'd be upset to discover this.
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I check edmunds.com and it does not list this specific TSB but does show the others like the brake ECU update. It might be that the TSB is fairly new.
  16. Mendel Leisk
    38,644
    I didn't say it was good practice, I said that's likely what happened. I don't agree with it either: thought I made that clear in my post. Ok, enough hair-splitting ;)
  17. pederson80
    Cambridge, Wi
    Well I just got my plastic cover replaced for free. I might be a little too paranoid but, I installed it myself. It looks like an upgraded cover. The fold line for the access panel looks like it was upgraded for sure. They didn't sound happy about giving this to me for free but, it was covered under the warranty so I think they had to do it. Thanks to all who helped. It is nice to know I can talk to fellow Prius owners about stuff like this.
  18. kfc2
    kfc2 Junior Member
    Chicago, IL
    I got mine replaced for free on last Sat as well. They wasn't sure if the repair would be covered by the warranty or not until I showed them the TSB. The repair totally took them about an hour.
