Washer Fluid Pump - '12 Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tonia taffaro, Feb 21, 2018.
  1. tonia taffaro
    tonia taffaro Junior Member
    83
    Can anyone post a video on how to replace this part?
    No whirring sound when wiper fluid arm pulled.
    Also, is there a website I can look for this part?
    49,507
    camel back toyota. once you find the part number, you can check eBay.
    have you checked the fuse, and tested the voltage at the pump while the lever is being pulled?
    Raytheeagle likes this.
  3. tonia taffaro
    83
    no, im not a mechanic, just wondering how easy it was.
    i can check the fuse, but i dont know how to check the voltage.
    probably end up bringing it in
    thanks for the reply, tho.
    Raytheeagle and bisco like this.
    49,507
    pleasure. yeah, checking the voltage would be easier than changing the pump. do you have a local gas station mech? might be cheaper.
  5. Mendel Leisk
    38,735
    Yeah, basically it'd be a sand-pounder, if you replaced the pump and it still wasn't working. You want to make sure voltage is getting to the pump. Say disconnect it's wiring connection, and see if one has 12 volts when the stalk is pulled.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I had to replace both of my washer pumps right around 60k. Luckily it was just before my warranty expired and they covered it.
