washer fluid reservoir leak...
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by MikeV, Sep 16, 2023.
  1. MikeV
    MikeV Junior Member
    95
    philadelphia
    has anyone else had issue with winshield fluid reservoir leaking. gen 4
    49,489
    sounds familiar, but maybe it was gen 5. can you spot the leak? have you tried putting fluid in an inch a day and seeing when it leaks? checked the connections?
  3. MikeV
    MikeV Junior Member
    95
    philadelphia
    it seems to be slow but its leaking from i think anyway the long goose neck piece that connects to the tank. it was replaced after an accident by insurance repair so the prev owner never drove it much and the shop that did the work states they do not warrant it since i am new owner
    49,489
    sounds like a simple replacement is needed. are they expensive? if so, maybe ebay or salvage
  5. Mendel Leisk
    38,726
    Could be it's just leaking till it gets down to the bottom of the filler neck? Not good, but worth checking. Work-around would be to fill with a light on it (if possible), and stop before you get up into the neck.
  6. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    My Gen III had that problem, leaking at the joint between the filler neck and the tank. The tank fits in the space ahead of the right-front wheel well and you can just see the tank top and seal below the filler neck at that transition. I never took it apart to reseat the seal or figure out why it leaked, just kept the top-offs below the filler neck. OP mentions front end damage so there may be some misalignment of parts allowing leakage.
    MikeV and Mendel Leisk like this.
