Washing Prii
Discussion in 'Gen 2 Prius Main Forum' started by orionll, Oct 1, 2006.
  1. orionll
    orionll Active Member
    1,115
    When I wash my car manually (using the garden hose w/ attachment) and some water hits it in the front and door handles the Prius locks and unlocks. Is this normal? It is a Package 7 2006 Toyota Prius.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(orionll @ Oct 1 2006, 08:33 PM) [snapback]326627[/snapback]</div>
    It's normal. Either ignor it or turn off the SKS with the switch under the steering wheel.
    All that is happening is the water fools the capacitive switches.
    Tom
  3. wtfjr
    wtfjr New Member
    38
    I hand washed mine this afternoon & had the same experience.
    Lots of clicking & popping going on in the doors, & I was wondering what was going on.
    Thanks for asking.
    Later.....
  4. DavidTO
    DavidTO New Member
    102
    You could also place your fob out of range.
  5. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Prius has her own way of doing things :)
  6. pirateprius
    pirateprius New Member
    149
    Eastern North Carolina, Home of the ECU Pirates
    <div class='quotetop'>QUOTE(DavidTO @ Oct 1 2006, 08:49 PM) [snapback]326635[/snapback]</div>
    I always put the fob back in my purse in the house after backing out of the garage so I won't forget it. I'm not used to having to take it out of the bottom of that black hole.
