Washing The Engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cireecnop1, Feb 18, 2007.
  1. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I read in the owners manual that it is not recommended to wash the engine compartment, I dont like this at all, Thats one thing that i pridemyself on is keeping the engine compartment as clean as the outside of the car. Anyway the owners manual says that you can't since the major HV stuff is in there? anyone have any suggestions on how to do this without damaging the electrical system.
    On other newer cars there are no risks with washing the engine, but I dont know if the manual those cars state the same as the Prius' manual.
  2. richard schumacher
    7,663
    1,038
    United States
    Get the wrong thing wet and you'll need hundreds of dollars in repairs. Is the risk worth it?
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(TomorrowMatters @ Feb 18 2007, 03:23 PM) [snapback]392471[/snapback]</div>
    Do not squirt water in there. I clean engine compartments on cars with sensitive parts by using some rags with hand cleaner for plastics and hoses, and a little WD-40 on a rag for greasy metal parts. I use the air hose to blow bugs out of the radiator and AC coils.
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    The only motor I've "washed" was the 302 V8 in my 1984 Ford F-150 - last summer. A motor in good shape without leaky gaskets and seals will stay very clean.
    For example, I noticed slight seepage on the valve cover cork gaskets when my Ford was about a year old. I never hestitated but replaced with new Felpro blue seals. The heads are clean.
    I noticed last summer the very slight seepage around the distributor was attracting dirt, so after removing the battery I carefully washed everything. Left it in the sun all afternoon to properly dry. Took off the distributer cap and made sure it was dry, etc.
    My Prius engine bay is spotless, so I see no need to fart around with a hose. One may argue that driving in heavy rain is the same, but usually the water hits the front of the motor, and from underneath.
    There was a TSB awhile back regarding the cowl seal. Apparently, it allowed water to come down on top of the valve cover, and this motor uses coil-per-cylinder ignition. Water would then enter the tubes under the coils, and cause a misfire.
    I suppose you can always do what Frank Hudon does: when he washes his motor, he removes each coil pack and uses shop air to blast out the tubes.
  5. cireecnop1
    338
    Pueblo, CO
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
  7. Beryl Octet
    1,293
    Abingdon VA
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    How'd you get that mud in there in the first place? My car is two years old and the engine compartment is still very clean. I just wipe it down every now and then with a damp cloth to remove the dust, then mist 303 over plastic and rubber and wipe that down too. Looks like new.
  9. richard schumacher
    7,663
    1,038
    United States
    Second that question. Are you taking the Prius offroad, or what? After 33 months the engine in mine hardly needs wiping down.
  10. jayman
    13,439
    640
    Winnipeg Manitoba
  11. Prius The First
    Prius The First New Member
    141
    Just wipe it down with a damp rag. No need to "hose" down the engine compartment. I, like you must have a clean - clean engine compartment. Even our 1990 Volvo 245 w/ 172,000+ miles on it is clean. It just amazes the masses.
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Mine has definitely fallen victim to the "northeast ick", and has
    a fine layer of sandy crud all over everything. And probably a lot
    of embedded salt, too. Every spring I hook up the hose to the *hot*
    side of the washer tap and basically empty the hot water heater into
    the underside of the car, maybe twice. Including the engine
    compartment, but avoiding too much deluge right *on* the engine
    especially where connectors are. Remember SSC50P and the dielectric
    grease in one resolver connector? Most of the sensor connectors
    around the engine and transaxle are pretty water-resistant, with
    internal gaskets, but it couldn't hurt to pull the accessible ones
    and blow the water out of them, and then at the very least go drive
    around for a while immediately after the washdown to get things warm
    and dry them out. A good mid to high speed highway run will do
    much to remove stray water before it becomes a problem.
    Pulling and reseating weather-exposed connectors once a year [if
    not more] is a good idea anyways; helps prevent them from going
    flakey.
    So wash away, just use caution around the engine/electrics and get
    it dried out asap after you're done.
    _H*
  13. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
  14. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    whatever you do, don't get water near the spark plugs or coils.
    otherwise, have at it. [but don't overdo it.]
  15. cireecnop1
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(Prius The First @ Feb 20 2007, 05:00 PM) [snapback]393595[/snapback]</div>
    Thank you! glad I'm not the only one. It's mostly the parts that are below the top layer of plastic covers and such that are full of dust+san+water=mud. no minor seepage yet but still waiting for it with a high pressure wash and maybe a scrub. Did I mention I take car ramps to the wash bay and wash the undercarriage thuroughly? I've only done this once to the Prius but summer is still ahead.
