Water-Alcohol Vapor Infusion System ( EWAI )
Discussion in 'Gen 3 Prius Accessories and Modifications' started by engerysaver, Nov 13, 2013.
Thread Status:
Not open for further replies.
  1. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    Just got finished installing and testing my, " Evaporated water-alcohol infusion system " on my 2011 Prius. This is not a injection system with a pump that sells for $ 400.00 + dollars. I only spent about $ 25.00 dollars, for 5 feet of 3/8 ID hose; 2 aquarium bubble stones; 1 straight plastic 3/8 ID valve; glue; several 3/8 ID fittings; 1 qt. plastic tank.
    I started by taking apart the air intake system and drilling a hole in the back-fire baffle, about 3 inches above the butterfly, ran about 3' of hose to the top of my tank, with about 1/4" of hose in a drilled hole in the tank, located just in front of the fuse box. I'm not happy with my tank, it is not what I want, it's hard to find something to fit in a small place. Will replace tank later!! Drilled another hole for a hose with 2 bubble stones connected to it placed in the bottom of tank. This hose is for air intake, I put a funnel on the other end and placed it where air would be forced into it when driving. Glued all holes with tubing in it; vacuum test all fittings, put everything back together. I put 60% water, 20 % alcohol, 20% methanol in the tank.
    Tested by driving 60 miles round trip with valve cut off; got 50.5 MPG. Next day I drive same route at the same speed with valve open; got 56 MPG, better overall performance ...... this just makes the fuel burn better ...... This installation does not bypass any EPA emissions devices, it's legal and so far it's working!!
    I will be doing more detail testing later on. If you like this info ...... Press Like ; Thank You. :)
  2. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    What is the theory behind how this works to get better mpg's. Also what is the impact on emission?
  3. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    What exactly does it do and would it later cause a scene at the dealer ship
    Turn off signatures in Tapatalk Tapatalk
  4. ETC(SS)
    6,553
    This isn't new technology.
    Water injection (engines) - Wikipedia, the free encyclopedia
    I'll wait and see.
    I'm thinking that the people in Aichi, Japan are pretty smart, and we already KNOW that they market the Prius by fuel efficiency numbers - which is probably one of the reasons that the MDF is optimistic by 5-10 percent.
    Maybe I'm just cynical, but I can't help but believe that if they could increase the real-world efficiency of the Prius by 5-percent just by bolting $50 worth of hardware onto the car they would be allllllll over it like a bum on a bologna sandwich!!!
    Besides....if they bought in quantity?
    We're probably only talking about $10 worth of stuff.
    I DO believe that ethanol injection is going to be a viable technology for very small displacement ICEs....and right now the bigs are tinkering with it, but I'm a little skeptical about suddenly getting 5-10 more fuel efficiency in a G3 without doing evil things in your crankcase.
    We'll see........
  5. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You can't test it if you want accurate data. Someone will have to do blind test.
  6. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    you got my attention, my son-in-law has a guy at his shop that made a "bucket hydrogen generator" and is getting 4-5 more MPG on an old ford pickup. I toyed with this idea but can't find the room for it plus I think it would freeze here in the winter.
    engerysaver likes this.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Interesting. An air pump like this could be used instead of relying on the "forced air intake" in your system.
  8. bisco
    49,445
    toyota wouldn't do it because they are not going to ask people to put water and alchohol in a tank every how often? i guess it could work, but i don't see enough details.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There will not be gains in efficiency with the Prius. You are spraying water and some combustible stuff into your cylinders. The Prius doesn't understand there is water in there, but you are taking away air and increasing the compression to the point that the power output will drop. Because the Prius' engine is not directly coupled to a transmission it is harder to sense this power drop in normal driving because the MG's will pick up the slack.
    Doing this continually is probably not a wise idea. There are 2 main reasons. Firstly, such a high compression ratio in the Prius is not smart. It was not designed for that. Even if there was an efficiency gain, is that worth it to have your engine explode in a few years?
    The second reason this is a very bad idea especially for the Prius is because you can hydrolock your engine. Water does not compress, that is basis for all hydraulics. Put too much water in the cylinder, and now you seize the engine and you have a very costly repair or replacement bill. Now the Prius is a special beast that can turn its engine on or off even when the car is moving. Normal cars, the engine is always going. So spraying a stream of crap into the cylinders will always be blown out. In the Prius, you are just soaking it when stopped, when then engine is off, or the worst case scenario is when you are moving above 42mph and the engine is spinning but with no combustion!!!! This is Prius specific and means you are in very dangerous territory.
    And Oldsmobile did this in the early 60's. Their Cutlass "Jetfire" model had a "Turbo-Rocket Fluid" reservoir. That was essentially this. 50/50 water and alcohol of some kind. But it's big engine used it for cooling and higher compression for more power. It had no computers tuning it, and so it works. This will not end will if it remains in your Prius.
    mroadster2k likes this.
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    He's not putting water into the engine, it's water and alcohol vapors . Big difference.
    SCH-I535
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    What do you think vapours are? Ice, water, steam, it is all H2O and all not compressible.
  12. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    I'd think that the Atkinson-cycle engine is an uniquely bad candidate for water injection precisely because the Atkinson-cycle engine aims to be thermally efficient in its operation.
    Disregarding water's anti-knock properties (which would only be relevant in an engine prone to knock, which might mean a craptacular one, or one that is designed to be running at extreme compression i.e. race engine), the idea behind water injection is that the water salvages some of the wasted thermal energy of combustion by turning into a gas and expanding in volume (read: added powering) during the power stroke.
    But the whole idea of the Atkinson-cycle engine is so that it has a longer effective power stroke, so that the added room for gas expansion doesn't just throw away the remaining energy (in the form of remnant exhaust heat/pressure) in the exhaust of an Otto cycle. So there isn't much heat energy to salvage.
    (The relatively low level of waste heat in the exhaust is also why Atkinson-cycle engines need to pay special attention to putting the catalytic converter really close to the engine, and insulating it.)
    The way I see it, the best case scenario is that the water salvages a meager amount of heat energy, and the alcohol adds as a fuel. Worst case scenario is that the cat is hindered from lighting off. And I have no idea what water in the cat (which persists because it never gets warm enough) would do to it.
  13. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Now that I read the OP again.... Jeebus Christ. There is no high pressure pump nor something to aerosolize the fluid. This is going to end badly.
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    Again, the liquid water is not going in the engine. Just, possibly, vapors.
    I'm skeptical that enough vapors make it into the intake to even make a noticeable difference. But who knows?
    All anyone can do is speculate all day long. This individual is actually using an implementation of it and, hopefully, will post results.
  15. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I foresee this thread getting vaporized into thin air.
    WE0H likes this.
  16. xliderider
    7,869
    3,116
    Honolulu, HI
    Here's an easy way to think about this "system".
    You know what a water pipe or bong is? This is pretty much the same thing, except there is only air going in, and instead of just water in the bong, there is the water/alcohol/alcohol mixture. Then what you have coming out is the original air plus, possibly some water and alcohol vapors.
    When someone uses a water pipe or bong, they are definitely not "inhaling" liquid, just "vapors". ;)
    WE0H likes this.
  17. ETC(SS)
    6,553
    It's probably easier to think of this system after a water pipe or bong..... :)
    WE0H, usnavystgc and DtEW like this.
  18. xliderider
    7,869
    3,116
    Honolulu, HI
    I just knew that one was coming. :D
  19. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    YET ANOTHER READ of the OP confirms what you're saying. This is indeed the automotive equivalent of a bong. Still a *facepalm* from me, though. Let's hope no sloshing of the tank will allow a significant amount of water to get capillaried and pushed into the intake.
  20. xliderider
    7,869
    3,116
    Honolulu, HI
    Well, that's what makes the PriusChat community so interesting, huh? We can have discussions on automotive applications of bongs and wheel balancing beads. :D
    WE0H and DtEW like this.
Thread Status:
