Water in cooling system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by redprius2011, May 16, 2022.
  1. redprius2011
    redprius2011 Junior Member
    46
    Georgia
    I had to use non-diluted water as the emergency situation and now before i add coolant i want to drain entire cooling system on my gen 3 2011 prius, the repair manual says prius can take about 7.3qts coolant and i only managed to drain about 5qts, is it safe to flush the entire cooling system with diluted water 2-3 times before i add coolant? is it possible to drain entire cooling system completely.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,980
    4,724
    Texas Hill Country
    Diluted water? Do you mean distilled water? It is difficult to drain the whole system. Use distilled water as a flush and then use the concentrated Toyota coolant.
    redprius2011 likes this.
  3. Mendel Leisk
    38,733
    I would flush with distilled water, drain as much as possible, start refill using Toyota Long Life Coolant (the full strength coolant, without “super” in description), put in half the specd capacity, then fill the rest with more distilled water.
    jzchen and redprius2011 like this.
  4. redprius2011
    46
    Georgia
  5. redprius2011
    46
    Georgia
    i bought Castle brand coolant from japan its basically same as "toyota super long life" upload_2022-5-17_12-58-30.jpeg
  6. redprius2011
    46
    Georgia
    How many times should i flush it? i think 2-3 times is enough
  7. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Flush your system once.
    Then, add fresh coolant and water.
    Fwiw:
    Why You Should Never Use Distilled Water in Your Cooling System
    Why You Should Never Use Distilled Water in Your Cooling System | Rislone
    Feel free to check other manufacture's recommendations.
    Btw, while softened water is the best, it's often not realistic, nor easy to get.
    The solution? Natural Spring water - like Poland Springs.
    #7 prius16, May 17, 2022
  8. rjparker
    7,980
    4,724
    Texas Hill Country
    Use distilled water. Toyota specifies 7732-18-5 water, which is distilled. Then the manufacturing process adds the chemicals and minerals the chemists believe is effective without the variability of filtering or softening.
    Softened water does have minerals, just fewer. That process does nothing for various chemicals that may be in untreated water. Along with adding sodium the ad dismisses. Finally the concentrate you are using has inhibitors for the very purpose of preventing corrosion.
    StarCaller likes this.
  9. prius16
    462
    243
    New England
    2022 Prius Prime
    Thanks for the info.
    (y)
    Distilled water is a "more pure" version of deionized water (no bacteria, etc).
    I saw on a Toyota web site where they say to use deionized water. I think the 50/50 mix even says it uses deionized water.
    So, distilled is fine. And, I'd say preferred in this case.
    Or, buy the pre-mixed Toyota antifreeze.
    For the slight price difference (antfreeze + distilled water), plus the ~80K/8year life of anti-freeze, get the pre-mix stuff, and don't worry about mixing the correct percentages.
    As always, check and use what the vehicle says to use.
    It clearly depends on the year/model of the vehicle being serviced.
    Thanks again for the updated info.
    (y)
  10. ASRDogman
    ASRDogman Senior Member
    6,093
    3,273
    mmmmm basically just the same as...... Used toilet water is basically the same as water......
    Unless you put that nasty sealer in it, there is no need to "flush" it.
    Drain the coolant, and install the CORRECT coolant that Toyota says to use.
    You are stressing out way too much about coolant!
  11. Mendel Leisk
    38,733
    I think nix the term “super”? It’s 100% coolant, no water dilution? That’s the important thing. The object is to fill a system that has residual water, and still achieve a 50% mix. You can’t do that with (50% pre-mixed) SLLC.
  12. ChapmanF
    15,660
    That would be absolutely the easy way to go, in most threads other than this one. The stuff is already mixed to the right dilution in the jug, so when your cooling system is already at the right dilution, you can freely top off from the jug any time and in any amount that you want, and never have to worry about the percentages you're mixing.
    But this thread is about a cooling system that got filled with straight water at one point. The problem with using the premix coolant now is that you never really get all of what's in the cooling system out when you drain. In fact, the amount you get out isn't very close to the published capacity. So then when you pour this premix coolant (the ratio in the jug is correct) into the cooling system with straight water left behind, the resulting ratio will be too low.
    That's why some posters will suggest using non-premix for a situation like this. Drain the system (leaving however much behind), then measure in the coolant concentrate (exactly half the published system capacity), then finish with more straight water (however much goes in). Now you know you're at 50%.
    One caveat there is that Toyota's premixed "SLLC" and non-premixed "LLC" aren't really the same stuff (even aside from being premixed or not). The LLC is an older formulation. I don't know a lot about the long-term compatibility between them.
    Another idea would be to just take extra pains to really get as much of the water out of the system as you can. Open the radiator petcock, and the weird cock on the back of the block that nobody gets much coolant from, and take the hoses off the exhaust heat exchanger under the car. Really drain stuff thoroughly. Maybe even blow a bunch of air through the hoses and passages. Then put it back together, refill with the specified premix, and call it a day.
  13. rjparker
    7,980
    4,724
    Texas Hill Country
    You could flush three or more times with Toyota Super 50/50 instead of distilled water and then finish with more Toyota 50/50 and achieve the same level of tap water removal at the end. However it would cost five quarts each time so the first three wasted flushes would be fifteen quarts (four gallons) at $25 a gallon rather than $1 a gallon for distilled water. Either way the process will take hours since you should warm up the engine to mix the flush before draining.
  14. redprius2011
    46
    Georgia
    Thanks for feedback, i got so confused which kind of water should i use, distilled or deionized water? Btw im not going to mix it with pre-mixed coolant, i'm going to buy Castle brand coolant (not pre mixed) its same as "toyota super long life" manufactured by a Toyota and the reason why i couldn't get "super long life" coolant is because i live in Georgia, europe and there is very bad and cheap coolant avaiable at a dealer, so i dont want corrosion in my cooling system.
  15. rjparker
    7,980
    4,724
    Texas Hill Country
    Use distilled for the price advantage over deionized. Super long life is premixed. Concentrate is not.
  16. Mendel Leisk
    38,733
    Again, it’s Toyota Long Life Coolant that is 100%: add the word Super and that’s the 50/50 mix.
  17. CR94
    CR94 Senior Member
    2,642
    1,138
    Northwestern S.C.
    But [Unsuper] Long Life is supposedly an older formulation, which had to be changed more frequently in the vintage Toyotas for which it was specified. Do you have inside information that they are actually identical, aside from the dilution factor? Who even knows whether Red LLC is even compatible with newer engines for which Pink SLLC is specified?
  18. Mendel Leisk
    38,733
    No, AFAIK you should change it sooner. It’s really too bad (Toyota…) that you can’t get SLLC full strength, for situations like this.
    CR94 likes this.
  19. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    IMHO it's close enough that chemically it's the same. You can look up the MSDS or SDS and check it out. Toyota started hiding with "proprietary".
    And I still hold that the reason it is not the same interval is because Toyota can't control whether you put distilled, deionized, straight tap water, tap tainted by hose particulates. So what does Toyota do, but take worst case and say covered. Those that use the distilled change it sooner than necessary but so what, we get more coolant sales. Why else wouldn't Toyota sell a pink concentrate? Because they know if someone puts tap they can't promise the same longevity. (Oh "I put distilled" says some claimant, lying)....
    REVVL V+ 5G ?
  20. redprius2011
    46
    Georgia
    Toyota sells high quality pink concentrate in japan called "Castle", its basically same as a toyota super long life but not 50/50 mixed, i can't get a super long life in my country so i have to use castle concentrate and mix it with a water, i can order "super long life" from usa but it will cost me so expensive cause of weight and transporting taxes.
