Water in the 12V battery well.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bunny45, Jan 19, 2020.
  1. bunny45
    bunny45 New Member
    Germany
    Hi guys,
    greetings from Germany.
    Since buying my 09 Gen3 in August 2017 I noticed that water would collect in the battery well during winter. I initially thought that it was the result of water running off the trunk lid when lifting it too quickly. But I wasn't entirely convinced.
    I removed the lining covering the right rear of trunk. Lo and behold I discovered that the two 10mm nuts retaining the tail light were loose.
    My initial reaction was to just tighten them.
    Curiosity got the better of me and I removed the tail light, revealing the crud that had accumulated over the years.
    I cleaned everything up and the well now remains bone dry regardless of how much precip has occurred.
    SFO, Mendel Leisk, CR94 and 4 others like this.
  2. ASRDogman
    ASRDogman Senior Member
    6,088
    3,273
    Looks shiny new! Glad you found your leak and it was a simple fix!
    What part of Germany?
  3. bunny45
    bunny45 New Member
    Germany
    OWL :)
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Good work! Exactly the same happened to mine.
  5. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Ostwestfalen-Lippe - I had to look it up on Wikipedia for my geography lesson of the day. Maybe one of these days I'll make a point to travel there.:)
  6. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    I put an aftermarket tail light in Mom's Gen 2 and noticed that the fit was not quite perfect. We left some paper towels in place to indicate any leaks. Maybe yours had some work done since the factory? It's obviously in good hands now! :)
