Water inside door?
Discussion in 'Gen 2 Prius Main Forum' started by KCobby, Jan 17, 2010.
  1. KCobby
    KCobby Member
    229
    74
    NYC area
    So I have the inside door panels off in front as I've been working on installing new speakers. But today when it was raining hard, I went into the car to check out another issue. That's when I heard "drip...drip...drip..."
    I couldn't figure it out until I noticed that the water was coming in off the window and dripping onto the speaker! Luckily I covered the speaker with a baffle for that very reason, but should the inside of my door be getting drips like that? It was a lot and steady. I still worried about the speaker too.
    I realize that the door does get moisture inside - hence the drain holes at the bottom. But this seemed excessive. Should I be worried about the seals around the window? Is there something else I should check?
    It's an 05 if that makes any difference.
    Thoughts??
  2. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    Water can -pour- into doors via the windows. That's why there are plastic sheets in there to control it. That's also why there are drain holes in the bottom of the door. When you install speakers in a door, you -must- install plastic sheet to control where the water may drip.
  3. KCobby
    KCobby Member
    229
    74
    NYC area
    Thanks for the reply. Yes, I agree that there needs to be some protection in there, but are you saying the existing plastic sheet does that? I'm not so sure.
    That wouldn't have stopped the water dripping on the speaker magnet. But perhaps you're saying that a new sheet needs to be fabricated when you install new speakers for this reason?
    Obviously, I'll need to do something - that just wasn't right. But the passenger side seems pretty dry - I guess that is why I wondered if I should be looking for a leak of some sort.
  4. Patrick Wong
    18,200
    6,479
    If you notice a big difference between the two sides, then maybe the driver's side window gasket is worn (say if you are in the habit of opening & closing that window much more than on the front passenger side) and needs to be replaced.
