Water leaking into battery well through seam above right rear passenger tire - anyone had this ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GasSippr, Mar 20, 2013.
  1. GasSippr
    GasSippr Junior Member
    56
    Cincinnati
    I'm creating a new thread to see if I can get anyone's attention who may have had this problem. I know some others have had problems with water below the aux battery. I noticed this the other day when replacing the aux battery. I tried to pinpoint where the leak was by pouring water over the seams around the hatch and roof but didn't notice any water coming in. Then I tried pouring water in the seam above the right rear passenger wheel. Pictures are posted below. The water comes through the vent on the body that is just next to the battery. Any thoughts on how to correct this?
    49,380
    i wonder how many of us who have never removed our batteries, and don't know there is water in there.
  3. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I will look, but when I put a yellow top in 3 years ago it was high and dry.
  4. GasSippr
    56
    Cincinnati
    That's a good question. One other member suggested that it could be from ?damage from a collision of some sort. The carfax was clean when I bought the car two years ago so I'm hoping that it was accurate. When I removed the old battery there was maybe 2-3 inches of water below the battery. It wasn't quite touching the battery yet. Hopefully that amount accumulated over at least the two years I've owned it, if not more. I don't know.
  5. GasSippr
    56
    Cincinnati
    Has anyone ever used silicone or any type of sealant on a visible seam like this one?
  6. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Do you think it is rain water or car wash water getting in there?
    I have not had a problem, but it is occasionally reported here, though I don't recall this area being cited as cause.
  7. GasSippr
    56
    Cincinnati
    I thinks it's probably both.
  8. GasSippr
    56
    Cincinnati
    In the second picture the bottom left corner you can see some brownish/yellow sealant. Does anyone else have this ? Aren't manufacturers supposed to paint over sealant? Maybe this is evidence of someone else's work if there was in fact some sort of collision/damage.
  9. khp
    khp Member
    76
    45
    SW Washington
  10. timbobo3
    timbobo3 Junior Member
    16
    I just found the same thing in my battery and wheel well when replacing the battery. I did have a rear end damage 5 years ago. Totoya also told me to check for debris in the hatch channel that could force water up under the gasket. The water explains the sloshing I heard last year. DOH!
  11. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    I've seen water enter on the rear driver side bumper/body seem before (should've taken pictures, may still).
    What was noticed were the retaining clips that hold the bumper cover to the body on the drivers side allowed water to dribble (or stream) into the shallow well below the drivers side removable cubby. To be honest I didn't actually see water flowing in with my own eyes, just a tiny amount of previous moisture that had collected and the tell tale sign of discolored trailing on the interior sheet metal which came from these plastic fasteners.
    My fix was to remove the rubber bung (which fell downward), and now the water can drain at will.
    Raytheeagle likes this.
  12. DC Torney
    DC Torney New Member
    Jemez Springs
    Thanks for mentioning this. I encountered the same problem: 1" water to the base of the Auxiliary battery.
    (It was frozen in Winter.) I sprayed the RR joint between the bumper cover and fender, behind the RR wheel,
    and water seeped into the well below the Aux. battery. I'll take the car to the body shop which
    installed the bumper cover, and they will make repairs.
  13. goodMXguy
    goodMXguy Junior Member
    44
    Philadelphia
    I have had the same problem at different times. I think the key is to make sure to close the trunk well when there is rain or snow in the forecast. I think this is a flaw of the Prius' design.
