Water pressure in coolant hoses
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Wraiththe, Mar 16, 2024.
  1. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    Heater was not functioning properly... or so it seemed. Went to check the level of antifreeze in the overflow tank and it was fine... but when I squeezed the @ 2"-3" hoses from the radiator to engine they were not under much pressure, I could squeeze them and they were not hard to squeeze or that hot. This is after driving for a few hours. Is that normal? @ 65 degrees out.
    Engine is not overheating... it would seem and there is no warning light coming on...
  2. sylvaing
    sylvaing Active Member
    1,027
    424
    Do you have white smoke coming out of the exhaust when accelerating hard?
  3. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    yes, sometimes. They say it is the heat exchanger issue.
  4. ChapmanF
    15,407
    The maximum pressure you'll ever feel there is about 15 or 16 psi (unless gen 4 is different; you can look at your pressure cap, it probably says something like 108 kPa which is around 15.7 psi).
    If you think of, say, squeezing a bike tire, 15 psi feels pretty soft. Definitely plumped out, but not rock-hard or anything. And that's the maximum pressure when the engine has been fully warmed up and running hard.
    Getting a Prius engine to be that hot sometimes takes a bit of effort. When I want to get it there as part of coolant replacement, I usually have to engage maintenance mode and sit there a while with my foot on the go pedal.
  5. sylvaing
    1,027
    424
    Then unfortunately, you might have your answer right there. It's more precisely the infamous exhaust heat exchanger issue.
  6. Doug McC
    Doug McC Active Member
    997
    374
    Midwest
    2022 Prius
    He has posted about the heat exchanger issue before. Round and round we go.
    Brian1954 and sylvaing like this.
  7. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    Yes, I guess I did, memory is the first thing to go. sorry, been dealing with other issues.
    I am going in for the bypass today. I just hope it wont make anything else worse.
  8. Mendel Leisk
    38,635
    Going in where? It's been reported here dealerships won't do it, would rather leave a steamy mess, because bypass "compromises pollution control components", or similar BS. Doesn't help that Toyota integrated the pricey exhaust heat recovery system with very pricey catalytic converter.
  9. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    I managed to find a prius mechanic that is willing to do it. On top of that, the exhaust parts are hard to find... or it was the last time I talked to him. He has the parts for the bypass. It will only cost $136
  10. sylvaing
    1,027
    424
    Yeah, it's BS because how many ICE vehicle has this heat exchanger? It just makes the engine warm up faster than a normal engine. I live in a region where it can get pretty cold (below -30°C) so of course this heat exchanger is beneficial here but enough to shelve over a $1000 more to fix "the right way"? Hopefully I never have to find out. Mine being a Prime, that exchanger is far less being solicitated than the one on a regular Prius. Will that change anything, not sure, but hope so.
  11. Mendel Leisk
    38,635
    @Wraiththe have you seen this:
    Around 2:50 he gets around to the in-the-engine-bay fix, which just involves hose reroute. Note, title says CT200h, but he mentions 4th gen Prius. Worth a watch anyway, might be DIY fixable, for free.
    Seems like a bad batch, from whomever Toyota had fabricating the Exhaust Heat Exchanger. Maybe they need to pull samples off the line and pressure test more. Whatever the problem is, Toyota is dropping the ball.
    Dealerships, and Toyota behind them, and the regulators, are all "right" in saying a bypass will compromise pollution controls, but all the circumstances considered, they're being pig-headed. Money's likely a big factor in their stance.
    #11 Mendel Leisk, Mar 20, 2024
    sylvaing likes this.
  12. ChapmanF
    15,407
    What's weird is gen 3 had the exhaust heat exchanger too, and theirs never developed any special reputation for springing leaks. Something about the way it's built in gen 4 didn't go so well.
  13. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    Yeah, I saw that one. Have fun removing the windsheild wipers and metal underneath it to get in there. LOL
  14. Mendel Leisk
    38,635
    @ChapmanF was it you that had some comment on that hose reroute (in video linked above). Someone I think commented about possible unforeseen consequences.
  15. ChapmanF
    15,407
    Well, in a gen 3, one of those two pipes running down has a tee off the side connecting to the EGR cooler. Leaving it open like that, you'd find out pretty quick. It may not be the same in gen 4 or CT200h.
    There could be more than one coolant path in parallel (as there is in gen 3). Making one path shorter / lower resistance than designed will mean less coolant flowing through the other one. No substitute for working through the details of the routing in whatever model you're working on.
    Well, that remove-wipers-and-cowl is kind of a universal prefix to a lot of work on a Prius (at least in some generations). After you've done it the first couple times, it gets like "chop ½ onion" at the start of every recipe; you barely notice yourself doing it.
    Wraiththe and Mendel Leisk like this.
  16. sylvaing
    1,027
    424
    How about routing a (coiled) hose the length of the currently bypassed one between both ends of the bypass?
  17. ChapmanF
    15,407
    That would be an idea. Or putting some sort of reduced-diameter orifice or restrictor in. The idea would be to try to get close to the flow resistance of the original hoses and the heat exchanger.
    But that's only if the car's coolant routing has parallel paths, so you could be starving one by making one too easy. If the exchanger is just in series with the other stuff, then making it easier isn't such an issue; that would only improve flow. So the details of the routing in the model being worked on are important.
    (Technically, all of that stuff is in the bypass loop, the one that's parallel to the radiator and thermostat. If you could make the whole bypass loop too easy, you might reduce the cooling effectiveness of the radiator. But that'd be pretty hard to do, as the radiator hoses have way more diameter than anything in the bypass loop.)
  18. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    So you are saying with the bypass I might have issues with passing inspection? Does that mean I should reverse the bypass? But it should be so nice to not have to buy and carry the antifreeze anymore.
    The mechanic said they cannot get the exhaust parts anyway.
    Did the one where you simply take two rails off the bottom of the car that are under the heat exchanger and take the connecting hoses off the exchanger and replace with capped hoses, and put a loop hose over the feed and exit hoses. System is looped and bypasses the heat exchanger. Then refill. It was supposed to cost 136, but he only charged 96.
    Hoping for no further problems. Wish I could just get one from a parted out car, but that runs the risk of getting another bad one. Why hasn't anyone figured out how to repair one. Just cut it fix it, reweld it. It is a water chamber, should not affect the harmonics. Even better, do it laparoscopically if possible LOL. They talk about the leak, but I have not been able to see where someone has done forensics on one of these. If I had a shop and money to burn, my curiosity would demand it.
    And since this is a known defect... and it is a defect... Toyota should fix it. But they won't, just like they would rather sell you a switch panel for a few hundred, than take the top off a switch and spray it with contact cleaner.
  19. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    To get it fixed by Toyota it is over $2k. The mechanic I know said he would do it for just over $1,600... I believe that was $1k less than toyota. Will look out of the estimate.
  20. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    Had the bypass done last week. Put 500 miles on it since. My gas mileage has gone up a little (says the dash) and no issues. For a while I still smelled a little antifreeze in the exhaust. Antifreeze levels are stable. No more carrying a jug around. They only charged me $96... it was supposed to be 136. Could have done it myself, 136 vs the aggravation: So worth it. (and the drive to his shop.) I will try to remember to post back a few months from now.
    Anyone who posts a mechanical question to make a decision should always come back and post the results.
