Water Pump Question
Discussion in 'Gen 3 Prius Main Forum' started by MelonPrius, Jul 3, 2024.
  1. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    I know this topic has been covered before, but I'd still like to get some feedback.
    At 120k miles, I'm going to replace my water pump out of precaution. There are no obvious signs of needing replacement. But I'll be taking a few trips this summer driving through long stretches of desert.
    1. Can I just replace the engine water pump, or is it common practice to replace both water pumps?
    2. While the mechanic is doing the work, is there anything else that needs to be done? I read in another thread that the thermostat should be replaced but I'm not sure how many miles they last.
    3. Does it matter which brand of water pump to use? What is recommended.
    I had my EGR cleaned at 90k miles. I'll need a new hybrid battery within a year (38% life left as per Dr. Prius) and don't know if I'll get a new battery or sell the Prius. So, I'm not looking to spend too much money just in case I end up selling the car soon.
    52,360
    i don't think we've seen enough water pump failures at your age and miles to bother
  3. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
    With the quality issues with pumps these days you may be trading in your original water pump that's more reliable for another pump that less reliable.
    And because these water pumps are easy to replace if they fail... Just buy a spare pump and watch a you tube video on how to replace it and wait for an error code telling you the pump is bad before replacing it.
  4. JC91006
    16,827
    8,600
    If you're thinking of possibly selling the Prius, I wouldn't bother changing out the pump. Mine had an error code at 214k miles. It was a over rotation code, it didn't actually fail. I went on Amazon and bought a new water pump rotor to replace the old unit. Yours at 120k miles should have plenty of life left (at least another 50k before you need to think about replacing it)
    I didn't want to spend a lot on this engine as it's nearing the dreaded "need head gasket" mileage. So I refurbished the water pump with a new rotor and it should last until the engine needs a head gasket.
  5. ChapmanF
    18,513
    There has to be an explanation for the overrevving though. Often it happens when a part of the pump impeller has broken off so that it can spin faster because it's moving less water.
    Another cause can be coolant so low it is spinning in air, which is also not ok.
    It seems like Toyota added the P148F overrevving code in 2011; a 2010's water pump can have its impeller break like that and you don't get a code, because its ECM was never programmed to think spinning too fast could be a problem.
    PriusCamper likes this.
  6. JC91006
    16,827
    8,600
    I did check the impeller fins and they were not broken. The thing I did notice was the thin plastic magnetic housing on the rotor was broken and somehow that made the impeller spin at an irregular speed.
    The error that came up was simply the temperature symbol on my dash. It came up for about 10 seconds and it went off. That's the only indicator of the actual error, the car was driving normally. P148F came up and the rotation was about 800rpm faster than normal
    My coolant was slightly low, maybe had to add 8oz a few months ago. I was worried that was a sign of head gasket failure but after adding the 8oz, the coolant has been stable.
    #6 JC91006, Jul 4, 2024
  7. PriusCamper
    13,021
    5,291
    Good example of growing pains for new technology... It's probably better than the older water pump tech, but at first it doesn't seem like it.
  8. MelonPrius
    839
    516
    Nevada
    Thanks for the input, everyone. Based on the feedback, I'll hold off on the water pump for now. I had a '96 Jaguar and I was on my 3rd water pump before hitting 110k miles. I love the Toyota dependability on certain parts.
    Thanks for the response. Just out of curiosity, what is your "need head gasket" mileage? (assuming it applies to my turd gen)
  9. JC91006
    16,827
    8,600
    The "need head gasket" mileage is after 160k miles on a Turd gen car.
    Brian1954 likes this.
  10. Mendel Leisk
    41,873
    Just my opinion: with thorough/complete EGR cleaning every 50k miles, the answer may be never.
  11. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Just throwing in something a dealership mechanic told me a few years back - He actually did say to keep on top of the EGR system even if Toyota officially never really says to clean/replace it. But he also said that the water pumps are known to go without any warning around the 100,000 mile mark (give or take of course). At this dealer they worked on a lot of taxi/Uber/Lyft Priuses and that was almost always the issue they found. From that, I just replace mine around every 100,000 miles. I'm almost to 180,000 miles so will likely be replacing it soon to be proactive.
    bisco and Brian1954 like this.
  12. VitoinTn
    VitoinTn Junior Member
    Clarksville, TN
    My daughter's 2013 with 169k mi started running a CHECK ENGINE light and intermittent TEMP light last week. Had low coolant in reservoir and had to show her WHERE it was. Topped it off.
    Now this week, same things...topped it off and hooked up code scanner;
    P148F Coolant Pump Over Revolutions
    P0117 Coolant Temp Circuit Low Input
    P261B Coolant Pump B Control Malfunction
    After the top off and a 10mi drive, the coolant level was back down to half in reservoir, but TEMP light went off after turning AC off. Haven't noticed any leakage underneath or in driveway with reservoir cap on or off.
    So am I looking at having to replace the Engine Coolant Pump?
  13. Mendel Leisk
    41,873
    The coolant will be disappearing somewhere. EGR and intake manifold ever cleaned? Any rough start-up after it’s sat overnight?
  14. ChapmanF
    18,513
    With those codes, definitely fix the pump problem.
    "Fix the pump problem" won't always mean the pump itself is at fault; sometimes you'll want to rule out a wiring issue. But in this case, both P148F (revs too high) and P261B (revs too low) suggest there is power to the pump and tachometer feedback from it and the problem is pretty darned likely to be the pump itself. Likely enough I'd probably go ahead and change it without much other troubleshooting first.
    The P0117 is scary. It means the temperature sensor resistance as seen by the ECM was so low the ECM thought it might be a bogus reading. The temperature sensor is a negative-temperature-coefficient thermistor (resistance goes down as temperature goes up), so bogus low input meant the temperature at the engine got so hot the ECM doubted the reading.
    You don't want that to keep happening.
    Brian1954 and VitoinTn like this.
  15. VitoinTn
    Clarksville, TN
    No drivability problem or start up problems. Haven't 'cleaned' EGR or intake manifold.
  16. Mendel Leisk
    41,873
  17. JC91006
    16,827
    8,600
  18. Mendel Leisk
    41,873
    Even if I type in “water pump”, or “water pump assembly”, I get at least 22 pages, and the water pump ain’t on page one, it’s wandered off into everything but water pump. Toyota USA did a job on that parts site.
    Have a direct link?
  19. JC91006
    16,827
    8,600
    I just tried that search function for the site, it's absolutely awful. This might have to do with the cyberattack episode they had 2 weeks ago. Can't seem to find the right part with the search function.
    This is the part that's needed
    Electric Water Pump Assembly
    Part Number: 161A0-29015 - It's $240.59 before the 20% discount and free shipping
  20. Mendel Leisk
    41,873
    $193.47 USD all-in. Amayama’s all-in price, converted to USD, at least at my locale, is ~$126. That’s with shipping, and with about 1/2 doz small purchases, never anything more, say tax, duty.
    It’s the Aisin WPT-190, but I believe the same. They’ve never had anything bogus in my experience.
