Water Pump Rotor Replacment Anyone?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AmazingFacts, Aug 6, 2021.
  1. AmazingFacts
    AmazingFacts Member
    112
    61
    San Jose
    Two Eco
    I'm having a overheating issue with coolant blowing out of the cap and P0117 and have came to the conclusion after reading many articles here (thanks everyone!) that I either have a bad water pump, clog somewhere in the cooling system, or air in my system. I've ruled out that it's not the following:
    -bad head gasket - drained oil and see that it's not milky.
    -engine temp sensor - tested and fine.
    Now I have drained the coolant and removed lots of marble size scales in the coolant reservoir and plan to flush the entire system.
    I've also inspected the water pump (OEM Asian) with all fins intact and freely moves, but upon removing the rotor, i see a small 1/2" split near the edge. My question is has anyone replaced just the rotor? I see Amazon has as PBAP brand for around $40.
    Any thoughts?
    SFO likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Thermostat?
  3. JC91006
    16,479
    8,395
    These water pumps don't give much warning before failing. Since you already removed it from the car, you should just buy a new one and be done with it. They are usually good for 150k miles or so.
    Where is the coolant coming out of? Reservoir cap? Is it too full?
    If you drain the coolant and there's chunks in there...maybe some additive was added to seal a leaking head gasket? That's a very common issue with these Turd gen cars when they get over 150k miles.
  4. AmazingFacts
    AmazingFacts Member
    112
    61
    San Jose
    Two Eco
    Thanks for your reply guys. Yes I just ordered a new thermostat and plan to replace the water pump as well.
    The coolant is coming out of the reservoir cap. No it wasn't too full. It was right between low and high.
    By the way, the high temp light came on and coolant leaked out while driving up a steep grade.
    I didn't see any head gasket additive in the coolant when I drained it. Coolant color was very clean and very little scale came out.
    I plan to flush the system out a couple times today then do the thermostat & water pump replacement afterwards when the parts arrive.
  5. JC91006
    16,479
    8,395
    Before you waste good money on this, go buy yourself a new radiator cap first. See if the $10 cap will fix your problems
    Raytheeagle likes this.
  6. AmazingFacts
    AmazingFacts Member
    112
    61
    San Jose
    Two Eco
    Yes thank you. Ordered today.
    I did end up flushing the cooling system and filled with coolant and made sure the coolant flowed/purged out of the tee where the temp sensor is. Then test drove and did a stress test up a medium hill in 100 degree weather with AC on. Engine temp reached 200 degrees and quickly came back down to about 190 after the hill. What's considered too hot and overheating for gen 3's?
  7. wr69
    wr69 Member
    140
    77
    portland, or
    Don't know what's too hot, but I think 212F is upper limit of "normal". A fellow named chapman has a lot of good data on this in other PC threads. It appears like engine will shutdown around 221F.
    For what its worth, Im just getting into the monitoring business with some new OBD gear. here are some rough computer readings on my 2010 (140k) and 2013 (65k). They are both behaving about the same right now, both with original water pumps. Am looking to proactively replace the 2010 pump soon, nevertheless. Portland, Oregon, 65-75F ambient air temp, running @ flat highway speeds, with no dramatic speed changes: The car runs about 195F. Seems like the computer works in gradations (or at least senses temp in steps of degrees), as its often "locked" at 195.8F. Saw it jump to 202 a few times - I think on a 85F day, when passing or accelerating. Around 60F, can go up a relatively steep grade (6-8%) and temp hovers around the 195F if I go 50-55mph. If I punch it a bit, it can hit the high 190's and barely break 200F for a few seconds, until I slow down. Based on my results, and your stress test data, I think you may have solved your overheat issue! hope this helps!
  8. Mendel Leisk
    38,682
    How many miles on it?
    Have the EGR system and intake manifold been cleaned?
    Is the coolant level stable in reservoir?
    Where would you use that cap? ;)
  9. ChapmanF
    15,533
    The various trigger points programmed into the ECM seem to be nice round numbers in Celsius, as you might expect for a car not designed in Liberia, Micronesia, or the US.
    While warming up, if the heater is on, it seems to disable the supplemental electric elements as soon as the coolant reaches 35 ℃. If the car is warmed up and the engine is cycling (because you are Prius-camping, for example), it seems to cycle off at 50 ℃. The thermostat starts to lift a bit above 80 ℃, definitely opening by 85 ℃. It should be fully open (10 to 14 mm lift) by 95 ℃. The electric fans come on if coolant reaches 95 ℃ (other inputs, like A/C use, can also trigger the fans).
    If the temperature reaches 105 ℃ and the ECM is reporting a water pump problem, it will abruptly shut down the engine at that point. (This comes as a bit of a surprise to the power management control ECU, which then logs its own code saying "weird, the engine won't start?".)
    If the ECM is not aware of a water pump problem, then nothing special happens at 105 ℃, but the red thermometer light will come on at 120 ℃.
    I drive with a ScanGauge always showing the coolant temp right above the steering column, and I pretty much never see it as high as 95 ℃, the fan-triggering temperature, except when I am parked and doing that deliberately, such as for burping the coolant. In normal driving, if I see above 90 ℃ I tend to notice, and if I see 95 ℃ I think about why. (Sometimes there's a ready explanation, like summer rush-hour traffic, or a big hill.)
    #9 ChapmanF, Oct 2, 2021
  10. Mendel Leisk
    38,682
  11. AmazingFacts
    AmazingFacts Member
    112
    61
    San Jose
    Two Eco
    Thanks for the reply guys. My Prius has 250k miles. Temperature has been stable after replacing the water pump and I plan to check/clean te EGR and install a catch can in the near future.
  12. AmazingFacts
    AmazingFacts Member
    112
    61
    San Jose
    Two Eco
    And yes coolant is stable in the reservoir.
  13. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Still haven't heard of anyone replacing just the rotor/impeller. Sure would be a nice data point to collect.
  14. ASRDogman
    ASRDogman Senior Member
    6,077
    3,270
    I was going to do that, but, I can't find one now.
    The used to be on ebay, but not any longer. I haven't check with Toyota to see if
    it's possible to just get that... probably not....
  15. StevilW
    StevilW Junior Member
    Seattle
  16. StevilW
    Seattle
    Found this guy on YT:
    AmazingFacts and Mendel Leisk like this.
  17. Mendel Leisk
    38,682
    It’s nice to see convicts take up a vocation, lol.
    seriously, I’ll watch again with sound turned up; didn’t want to wake the missus. Thanks!
  18. ASRDogman
    6,077
    3,270
    OLD news.... wonder why he didn't say WHERE he got them???? (n)(n)(n)
    I got mine off ebay....
  19. Mendel Leisk
    38,682
    Yeah, checked at the original youtube posting as well, no info.
  20. Professorman
    Professorman New Member
    Hampton, VA
    No one else has found a good reliable way to do this? Would be nice to find a Asin rotor, or from who manufactures it.
    AmazingFacts likes this.
