Water Pumps and Sourcing
Discussion in 'Gen 3 Prius Main Forum' started by Frontporch, Mar 24, 2025.
  1. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    My 2012 has around 190K miles and I would be surprised if any water pumps have been replaced. I know there is a general rule of thumb about the engine coolant pump and I think I am due for that. On my gen2, this would be about the miles to replace the hybrid pump and I bought OEM for the gen2 in the past. Cleary both pumps pretty much stop you in your tracks... and make long drives unreliable.
    Does the inverter pump on these cars typically go bad around this time?
    For both pumps, is sourcing an AISIN at Rock Auto a safe bet? I saw cheaper ones at Amazon, but I don't know what the heck they are doing there, with all the water pumps having the TOYOTA log scraped off. Are those quality control failure units meant for Toyota?
    Also... anyone watch their electric water pump using torque or another app that shows pump RPM, etc and able to see signs of failure before it quits?
  2. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    Usually you can put your hand on the main water pump ice engine water pump and feel that it's not running properly It's chunking out it'll spin a little bit then it'll stop abruptly spin a little bit stop abruptly if your hands on it you might be sensitive enough to register that I'm not sure what you'll see on the app or even in tech the Toyota software I've looked at it before but I don't remember if it'll show you that the pump is not a steady RPM continuously so if it's chunking out because the plastic is splitting off of the impeller cover it'll call for $2,200 RPMs but it'll only be running $850 and stopping for a second or something similar You can buy an impeller for like $30 that's not much to it it's a magnet with plastic over it and so on or you can buy a whole pump whatever makes you happy finding out if it's working or not it's yeah pretty quick You can tell by an app like torque that it is in fact called and should be spinning. Then you look at your water temperature to see if it's in range and if you are starting to overheat and your pump is on call then it must not be on call enough and it's time for you to take it off and look at it or at least put your hand on it while it's on call and see if you feel any spinning you can listen to it with a mechanic stethoscope whatever your fancy or you can just pull it off in about 18 minutes and have a look for yourself and stop all the hype. Some of this stuff all the tooling and time and diagnostics you're doing you could have just pulled the pump off and be holding it in your hand and have the cover off and looking at the split impeller.
  3. ETC(SS)
    6,952
    Are you on your first or second head gasket?
  4. Frontporch
    494
    107
    Nj
    Original head gasket as far as I know. Car is new to me
    Are those for sale separately? Oem?
    Tombukt2 likes this.
  5. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    I don't know what criteria is used to remove the TOYOTA logo casting from the pumps... but given the importance of the part and the track record of (at least some of) the ones that were ground blank, I will just pay for the real one from an online Toyota part dealer. It's usually cheaper than MSRP.
    Brian1954 likes this.
  6. Tombukt2
    12,193
    2,150
    Durham NC
    I'm not sure Toyota will sell you an impeller That's not how they do business The impeller is just a round device with a magnet on the back of it wrapped and shrouded in plastic It's mag drive so an impeller is not really a thing I mean it's not super mission critical production The factory ones that I'm taking out are the ones that are all peeled and shredded so I'm imagining some manufacture might have the wear with all to use some plastic that makes sense and we'll go a little more distance of course the opposite could happen too usually if you observe and look at the plastic of the product you're buying which you can't do till it gets to you You can maybe have a good idea of what's happening I've done both bought pumps and impellers no problems either way I'm not really a big fan of electric water pumps That's why another reason why I'm in the generation twos but oh well.
  7. bisco
    51,139
    Idk if rock auto is safe from counterfeits or not, so unless someone can guarantee it, I’d stick with dealers
  8. Frontporch
    494
    107
    Nj
    I don't see an OEM impeller, like you said.. only the entire pump. Found one from a Toyota dealer in Mass. for $237. That's only 30 more than rockauto for the AISIN brand. The inverter coolant pump from the same dealer is also $230. I was surprised by this. It looks similar to the gen2 one and I thought that was only slightly above $100. I may be mistaken.
    Anybody replacing the inverter coolant pump as part of maintenance?
    I had mine fail on a Gen2 at about the same mileage on a long trip and that wasn't fun. I just checked and the AISIN inverter coolant pump from RockAuto is under $100.
  9. Frontporch
    494
    107
    Nj
    I remember when I was searching for Gen2 Phillips HID headlights, many people recommended RockAuto as the one supplier that deals directly with the manufacturer and was safe from counterfeits. Haven't heard the contrary as of yet.
  10. bbrages
    bbrages Member
    163
    47
    St. Louis
    I bought an Aisin from a Japanese eBay seller. Looked legit. So far, so good.
  11. bbrages
    bbrages Member
    163
    47
    St. Louis
    Replacing just the impeller with a no name part makes no sense to me. The impeller is the single moving part and is also the part that fails. You want to go Temu-grade on that?
  12. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    Don't waste your time or money with rock auto..... Lot's of fake cheap chinese copies,
    and just crappy stuff. They were once a good place, but no longer.
    If you're not going OEM, try autozone or similar, at least they are local and when/if the part fails,
    you'll be able to get a replacement a lot faster and easier....
  13. Frontporch
    494
    107
    Nj
    I have never had a bad experience with rockauto. What they are guilty of is selling economy parts at low prices. Sometimes you get what you pay for. Need an economy parts at low price to keep you going? They offer that. What they don’t do is give you an unbelievable deal on a well known brand and deliver a counterfeit or used part.
    my choice is the get a trusted brand at a great price even considering shipping
    I will shop at the local auto parts stores but I have seen their house brand parts at 2x the cost of RA. If you can wait a few days I would never buy brick and mortar
    I also had the experience buying an alternator at a local retailer for under $100. After it was installed and thew off a cloud of sparks and destroyed itself the guy at the counter said he would only buy that part if he was selling the car. Why is that part even offered and why would I put crap in a car and make it someone else’s problem?
  14. Tombukt2
    12,193
    2,150
    Durham NC
    You're right the impeller basically is the only moving part It's like a mag drive pond pump basically the impellers of magnet wrapped with plastic I'm not sure you could go temu on that . But just about anything wrapped with the more modern polymer might be a good move and it just takes 20 minutes to put it on It's not like you're doing a 4-hour job here holy Christ so it's a $35 impeller stick it in there and it's working If you're scared of it you can monitor it with your software for a while till you get not so scared and that's that or it's I don't know what it is now for a pump 230 240 250 so I mean I'll take the $35 in the 45 minute option any day either one is 45 minutes swap out so I'll take the $35 anytime I have not seen an aftermarket impeller I'd have to hold it in my hand and see it but I'd still put it in and run it I would think some of the more modern plastics they're using today might have a chance of holding up better or it could be cheaper and hold up the same or a little less which is still most of you guys are changing these things it 150 plus thousand.
  15. ASRDogman
    7,232
    3,774
    I used to buy a lot from rock auto.... but not anymore. In the last few years I've purchased
    at 4 different times. Each time it was junk.
    Last time with struts, front and back. As a package. One of the front's failed in a few hundred miles.
    It took 2 weeks for me to get a replacement. Another 2 week AFTER they received it to refund the
    money I had to pay to get the replacement.
    The rear shocks were not even close, and didn't fit. They tried to blame it on me!
    They came as a package!!! Another 2 weeks for replacements.... And 2 weeks for the refund.
    So much for a lifetime warranty. After one replacement, they cancel you.
    3-4000 miles later, both fronts failed. They wouldn't replace the one they already replaced stating
    it was not going to resolve MY issue! So they blamed ME for it failing!
    So I wanted a refund. No sense in replacing 1 strut!
    And I couldn't get a person to talk me. Only emails. Another royal pain!
    It took about a month to get a refund and they didn't want to refund the shipping.
    I had to have someone I know go into their system to get my money back for that.
    I went to autozone and got a set of front struts. So far so good.
  16. Frontporch
    494
    107
    Nj
    I would blame the manufacturer for the part and blame rock auto for the refund processing. I do think about the issues of dealing with a seller far away especially when there are cores to return. In the past I have been able to get someone on the phone for help with an order. I rarely need it but it’s nice to talk to a person. Seems like that is becoming more rare
  17. ASRDogman
    7,232
    3,774
    It's junk. They're getting junk parts.
    I won't waste my time or money with r/a. They're going cheap.
    There is no customer service any longer...
  18. rjparker
    rjparker Tu Humilde Sirviente
    9,588
    5,888
    Texas Hill Country
    You will sometimes get a
    P148F engine coolant pump over revolution code and or you can watch the coolant temp in realtime to better understand how the cooling system reacts to load and ambient temperatures. The engine cooling system is quite effective in every normal situation; sometimes too good as it drops temps fast in engine off while using ac in Ready.
    I set a lower limit of 210f on my coolant temp device (rather than the car's 248f) and have only seen it once after I accidentally left the reservoir cap slightly loose.
    I am not a member of the change water pumps preemptively school. I prefer to change coolant often and average 30k-50k between drain and fills.
    I also try to mitigate 149f inverter coolant temp alarms in high ambient traffic jams. Usually it means reducing ac run times and the obvious, staying out of the situation with alternate google maps routes.
  19. Frontporch
    494
    107
    Nj
    Your experience is not good and I understand why you won’t do business with them anymore. I would do the same. Until it happens to me I appreciate having them as one of a few alternatives for less costly aftermarket parts. I am not a fan of the local chains and it doesn’t help me much if I break down far from home but have a lifetime warranty
    Can you share a little bit about your setup? The display and how it’s wired? I setup torque but it’s a tablet that looks like I am driving a police car. I also still need to figure out which of the gauges work. Some that are offered show no readings
    I would also be interested in the expected temp ranges for both inverter and engine cooling if you have them
    one of my few gripes with the Prius is the lack of instrumentation.
  20. rjparker
    9,588
    5,888
    Texas Hill Country
    P10 "heads up" display $35 for current versions like P12 on ebay. It seems the most popular version is now:
    Car Digital Head Up Display OBD2+GPS HUD Gauge Speedometer Turbo RPM Alarm Temp | eBay
    Runs from obd2, has many display and alarm options along with configurable sleep modes and communication busses so proper setup is required. Engine coolant typically 185f to 204f but sometimes drops 40f. Inverter coolant up to 149f before vehicle alarm, varies widely and quickly.
    #20 rjparker, Mar 25, 2025
    Frontporch likes this.
