Water-rain-bottom of 12v battery "box"-best guess?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by phoebeisis, Nov 26, 2013.
  1. phoebeisis
    phoebeisis Member
    139
    When I had to change the 12v battery(2006 prius)-I noticed water-rain in the bottom of the 12v battery"box"
    I live in a suburb of New Orleans so
    1)Plenty of rain
    2)Plenty of tree leaves
    We did have a build up of leaves pollen debris in the hatch track-where the hatch meets the body of the car-
    There are seams "everywhere"
    The sound deadening felt above-behind and lateral-to the battery is slightly damp-
    and where the main battery duct meets the grill-it is slightly damp.
    Best bet-where is the leak?? Any guesses appreciated.
    It took me almost 5 years on and off to find a rain leak the 98 suburban had(I should get a sticker"my other car REALLY is a Prius)-so any guesses greatly appreciated-rain leaks are tough to find sometimes.
    Thanks
    Charlie
  2. Patrick Wong
    18,200
    6,474
    1. A leak in one of the taillight gaskets
    2. A leak in the hatch gasket
    3. A leak in a body weld of the sheet metal, adjacent to the hatch opening
  3. phoebeisis
    phoebeisis Member
    139
    Patrick
    Thanks
    I will eyeball the hatch gaskets-leaves were "stuck" in there they might have deformed or cut the gasket
    There is a gap above the tail light-meant to be there but it sure looks like water could get in-it is normal-on both sides-guess I should ignore that.
    When it gets light I'll take a much better look-and when the weather improves-guess I will be spending a lot of time with a hose
    Thanks
    Charlie
