Water sloshing sound when turning?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusVancouver, Nov 19, 2007.
  1. PriusVancouver
    PriusVancouver Junior Member
    After my car has sat in the rain for a small amount of time, when I start moving again and then turn, I hear a sound like water sloshing around inside the chassis of the car. It will happen once, then stop unless I sit still for a while in the rain.
    Is this a normal function of rain water being guttered after falling on the chassis and then drained? If not normal, does anyone have an explanation or experience regarding this?
    Thanks.
    Adrian.
  2. phil.albericci
    phil.albericci New Member
    Adrian
    Not going to be a helpful reply, but I get exactly the same after the car has been standing in moderate or heavy rain. Don't think its linked to the engine cooling system (see "gurgling noise" post by ggarman). It can occur a minute or so after ICE start, it seems to be linked to cornering, and it only happens once per journey.
    I think it's rainwater trapped in some internal drainage channels. These may be blocked, perhaps by leaves as I do park under trees. I don't worry about it too much (until the body rusts through....)
    Any more comments / advice would be gratefully received!
    Phil
    (Prius owner 18 months; avg mileage 58 UK mpg)
  3. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    My guess is that you park your car outside under trees.
    The sloshing sound is water moving from side to side in the reservoir which holds windshield water run-off . . . the drain holes are clogged.
    For a quick confirmation:
    1) Open the hood to the engine compartment.
    2) On the passenger side, toward the back, under the windshield, is a rectangular cover with air slots and screening. Pop this off from either the left or right side (very easy to do with just your fingernails if they are long and strong enough).
    3) Look inside at the bottom back. If you see a bunch of gunk but no drain hole . . . it's clogged.
    4) There is another drain hole on the driver side, but it is not as easy to get to.
    Check out earlier posts of mine for pictures . . .
    http://priuschat.com/index.php?s=&show...st&p=446515
    . . . and this thread I started on the subject. The pictures were lost due to one of the Great PriusChat Crashes, but the directions on how to clean the driver side is still there. (some day I will clean my drain holes again, take more pictures and re-upload them)
    http://priuschat.com/index.php?showtopic=22839
    Why Toyota made the drain holes that small, and made access to the one on the driver side - I DON'T KNOW - but I feel it is a design flaw as I get the water sloshing sound several times a year to remind me to clean out the drain holes. <_<
  4. patsparks
    10,664
    567
    Adelaide South Australia
    The plastic panel at the base of the windscreen can catch water and will slosh out to the sides when you go around a corner. This is better than the water running over the engine.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    You've got this problem.
    Refer to cowl removal instructions here to pull the plastic if you
    want to do a more thorough cleanout job...
    _H*
  6. PriusVancouver
    Hobbit was correct. Luckily it was only the easy one on the passenger side that needed cleaning. Quickly popped out the plastic cover, scraped out the rotting leaf type material and dirt and all was well.
    Thanks!
  7. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I had the same problem that started recently (Either I didn't have this problem in the last 4 years or didn't notice it). PC is awesome! Removing leaves/gunk from the passenger side drain was really easy even for me. I think this is the first time I even opened the hood. :rolleyes:
    1. Leaves
    2. Removing the plastic thingy (super easy)
    3. Clogged drain and accumulated water. I was able to put my entire hand through (I have a skinny wrist :D) and unclog the drain. Water went gushing through.
  8. bisco
    49,371
    well done!
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Thanks! I was wondering what that slice of removable piece was for.
    I put some mesh to cover the large openings at the two ends of the plastic cowl cover, hoping to block these largest entry points for leaves:
    http://priuschat.com/forums/gen-ii-...ng/71909-diary-wimpy-diyer-2.html#post1193787
  10. Patrick Wong
    18,200
    6,471
    When removed, you can see the VIN stamped into the bulkhead.
  11. Michgal007
    1,321
    98
    Macon, GA
    Thanks Patrick, it was a photo you posted that helped me a lot. Even after opening the plastic thingy I couldn't see the drain because it was so clogged. If I hadn't seen your photo I wouldn't know there was a drain there.
  12. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    could be that or like I found on mine after heavy rains the 12V battery area has about 3" of standing water in it.
    there is a small soft plug/gromet in the back left corner of the battery area, drill a hole in the center and it solves this problem.
  13. 2009Prius
    2,705
    510
    63
    Would be nice to fix the source of the leak in addition to draining it though. Just my 2 cents.
  14. striker308
    302
    43
    I agree if you can find it, I don't know where to even start since you would have to be able to see through the back deck to see it.
  15. 2009Prius
    2,705
    510
    63
    People have found leak through the rear light housing seal, also various seals and weld points along the hatch seam. Maybe on a dry day spraying the back with garden hose would help finding the leak. Good luck!
  16. striker308
    302
    43
    If we ever get a dry day in in western NY I'll try that.
