Waterfall console rattle solved... OLD SCHOOL METHOD!!!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dconner9, Feb 6, 2010.
  1. dconner9
    dconner9 New Member
    New Canaan, CT
    On my Gen 3, I have solved the problem of my waterfall console rattling by going old school; not high tech... Check out the picture! I cut a piece of wood the perfect length to wedge it into the perfect spot, and NO MORE RATTLES!!!
    Seems crazy to have to do this on my brand new $34k car... so; does anyone have any better suggestions?
  2. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    A better ida...Ummm...wow..maybe a piece of black ABS pipe sanded to make it grey and matt like to match the interior colors better???
    (Oh and by the way, congratulations- you've just voided your warranty!!!! ;) )
  3. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    Now that you've done the leg-work, maybe have the dealer fix it?
  4. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
    Can't you just put some teflon tape in certain areas?
  5. mike lipke
    mike lipke New Member
    89
    MN
    (Oh and by the way, congratulations- you've just voided your warranty!!!! ;) )[/QUOTE]
    Wood has a warranty?
  6. mmichaell
    mmichaell Member
    241
    chicago
    I did this - place some grey fabric/felt and wedged it in the console crevice. Doesn't look "great" but it does the job.
  7. MikeDS
    MikeDS Member
    298
    Los Angeles
    Did you pul the console apart to do that, or just shove it in the crack?
  8. mmichaell
    mmichaell Member
    241
    chicago
    Just forced it in there, it can only go so far, maybe an inch or so. I suppose if you wanted it to be not visible you could cut up some fabric and make it only an inch long or so. I used the same tough fabric that I used for my cargo liner that I cut out to fit the cargo area, so its easy to wiggle into there.
  9. mastercut
    mastercut New Member
    italy
    :D:DPlease send this pics to the TOYOTA and say them that for $34k car they have to send u a small japanese that will hold your console
  10. dconner9
    dconner9 New Member
    New Canaan, CT
    Thanks for all your help
    i put the wood in there for a temporary fix until the dealer can actually look at it.
    curious how the wood would void a warranty? it is just wedged in there; no screws or anything. When i bring the car back in to the dealership, I will take the wood out and ask them to address
    Appreciate all your thoughts though
    Dave
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    It's a joke. :doh: Whenever the car goes in for warranty work the SM claims the aftermarket equipment voids the warranty so the owner has to pay big bucks for the fix.
  12. georgew
    georgew New Member
    129
    you should totally write toyota asking them to let you sell that as a Prius accessory in their service shops
  13. dconner9
    dconner9 New Member
    New Canaan, CT
    It's the new WDS
    Wood Dowell Solution... Only $49.95!!
    Act now... supplies unlimited!
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Thanks, I'll try it tomorrow myself. Now we need a fix for the glove boxes and the center console box.
