Waterproof keys?
Discussion in 'Gen 3 Prius Main Forum' started by rsgillmd, Aug 28, 2011.
  1. rsgillmd
    rsgillmd Junior Member
    38
    Memphis, TN
    Last weekend I went scuba diving. After unloading my gear I forgot to put the keys back in my bag. I accidentally left them in the pocket of my swim shorts. That is where I found them when I went to change.
    My dive was to a max depth of 28 feet for 58 minutes, with most of it spent around 25 feet, because there was a thermocline at around 26-27 feet. The temperature above the thermocline was 81, and below the thermocline was 75. No wetsuit. It was fresh water.
    Luckily for me, not only did I not loose the keys, but the keys worked.
    While I would not recommend trying this again, it is reassuring that the case of the keys is pretty waterproof. While I was hitting myself for my stupid mistake, I also found it amusing and thought I would share my experience.
  2. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    You may want to rinse the keyfob in clean water. Salt water in particular can cause damage, if not right away, then shortly thereafter. Take the keyfob apart as if you're going to change the battery. Circuit board cleaner (ask for it at Radio Shack) would be better, but don't delay.
    Next time just take a mechanical key. Leave the expensive keyfob in the car, wrapped in aluminum foil so that the electronics can't see it. Lock/unlock the door with the mechanical key.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Yeah, someone ran his through the washer and it still works.
  4. steveb123
    steveb123 New Member
    New York
    I had never experience this kind of situational in my life, from today will also take care of mine car key may be it will happen with me also.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    That's not a thermocline, that's bath water. :D Around here I feel lucky if the water is still liquid below the thermocline.
    (Don't think too hard about that statement, or you will feel obligated to call the physics of it into question.)
    Tom
  6. Minion
    Minion New Member
    38
    New Jersey
    Sure you weren't wearing a dry suit?! :p
    75 degrees under a thermocline? I wish we had dives like that in NJ... :D
  7. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Yeah, a few months after I got my Prius, my swimming trunks, with a key fob in them, went with me into a hot spring in Big Bend National Park.
    My wife would have killed me if it hadn't worked when I got out.
    But I'm still alive, so you know it did.
    But like everyone else, I've tried real hard not to do it again, especially since I found out the price of a replacement.
  8. Mendel Leisk
    38,719
    I'd also open the fob up if it's been submerged, to help in drying it out. They're definitely not water-tight.
