Way to adjust steering sensitivity
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by amilamad, Nov 2, 2015.
  1. amilamad
    amilamad Junior Member
    Hi
    I`m wondering is there any way to adjust the steering sensitivity of the prius c ?.
    Thanks
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    By "steering sensitivity" do you mean the steering ratio (degrees of rotation steering wheel per degree turn of steered wheel), the sensitivity of the power steering , or what? Please clarify.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Lighter steering effort? More responsive steering "feel"?
    If you want better response to steering input, you generally need a shorter, stiffer sidewall. In other words, larger diameter rims with lower profile tires.
  4. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    No. Not unless you know hoe to hack the module, and reprogram it... ;-)
    mertechperformance likes this.
