Wayne's Roller coasting
Discussion in 'Gen 2 Prius Fuel Economy' started by bmg21, May 21, 2008.
  1. bmg21
    bmg21 New Member
    22
    Rochester MN
    I'm a new poster trying to master all the hypermiling skills in my old car before my 08 prius comes in. He mentions roller coasting in his interview when he trekked from Chicago to NY. My question is what exactly is roller coasting? Is it take a slow acceleration up hills, then speed down them while trying to enter warp stealth? If anyone knows please chime in. Thanks much
    Brandon
  2. bwilson4web
    16,010
    It is another label of what is called 'terrain driving.' The principles are:
    • ascend the hill at an engine efficient speed - for example the speed of a truck in a climbing lane is perfect, ~55-60 mph
    • ballistic glide on the downgrade - let the speed increase to whatever is safe
    • avoid climbing a hill so fast as to put the engine in inefficient power ranges, 65+ depending upon grade
    If you are on a four lane road, this works great if you stay in the outside lane and perfect if there is a climbing lane. But on a two lane road, the passing zones are often after the crest of the hill and accelerating here while creeping up the climbing side will madden the following traffic.
    However, I would recommend heading over to CleanMPG to get Wayne Gertes' exact description of "roller coaster." But before you do, you might take a peek at the PriusChat stickies that address hybrid driving as well as Wiki.
  3. bmg21
    bmg21 New Member
    22
    Rochester MN
    Thanks Bob
  4. douglas001001
    douglas001001 smug doug
    222
    Chicago
    You'll want to get a scan gauge so you can monitor what the engine is doing for settings you can control. When climbing a hill you want to pick an RPM that will barely maintain or slowly lose speed as you're climbing.
    On the back side of the hill, either use warp stealth of super highway mode depending on hill size/state of charge/ terrain after the hill. I don't think anyone has published a chart on when to choose one over the other.
    After you get a scan gauge I'd suggest watching how the car works in cruise control, what RPM/IGN/TPS does as the car moves along then practice and learn how to do it on your own.
  5. Bob64
    1,540
    93
    Virginia
    Consider using "warp neutral" to get a feel for how it the car should
    de-accelerate if your doing warp stealth right.
