We have a 2015 V and never got the recall completed
Discussion in 'Prius v Technical Discussion' started by gonegreener, Oct 25, 2024.
  1. gonegreener
    gonegreener New Member
    Arizona
    2015 Prius v wagon
    Hybrid System may shut down and cause stall. OEM code 20TA10 has anyone had this done and had a problem within 4000 miles? I ask because our friend had it done to his 15 V and about 4000 miles later had a computer problem that cost him out of pocket $ 2750.00 So we have been leary of getting it done since it runs great. Any input would be appreciated thanks What is it that Toyota actually does for this recall?
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    Depends which tsb you are talking about. The inverter had a software update everyone was encouraged to get to avoid sudden failures. However many got that update and still had a sudden inverter fail which stranded them.
    IF that was the problem, Toyota Corp would have covered the repair free.
    BUT some owners have had the inverter failure and paid the dealer for the repair. The dealer rep you get does not always know about this 15 year extended warranty.
    Again it depends exactly what the repair was.
    Tim Jones likes this.
  3. gonegreener
    Arizona
    2015 Prius v wagon
    20TA10 is the recall notice we received in the mail about a year ago. We were out of state and never got it done. Just wondering if its worthwhile to have it done or if it will actually cause a problem.
  4. gonegreener
    Arizona
    2015 Prius v wagon
    1 Unrepaired Recallsassociated with this VIN
    Jun 24,2020
    Manufacturer Recall Number20TA10
    NHTSA Recall Number20V369
    Recall StatusRecall Incomplete
    SummaryThe involved vehicles were designed to enter a failsafe driving mode in response to certain hybrid system faults. Toyota has found that in rare situations, the vehicle may not enter a failsafe driving mode as intended.
    Safety RiskIf this occurs, the vehicle could lose power and stall. While power steering and braking would remain operational, a vehicle stall while driving at higher speeds could increase the risk of a crash.
    RemedyAny authorized Toyota dealer will update the software for the hybrid system performed FREE OF CHARGE. For customer satisfaction, if the vehicle has experienced an inverter failure with certain hybrid system faults related to this condition, the inverter assembly will be repaired or replaced FREE OF CHARGE
    Air_Boss likes this.
  5. Air_Boss
    Air_Boss Senior Member
    4,132
    1,151
    New Yawk
    Why would you choose not to get it done?
  6. rjparker
    9,485
    5,808
    Texas Hill Country
    It is the inverter fail issue and repairs are still available free - if you know to ask.
  7. gonegreener
    Arizona
    2015 Prius v wagon
    Because if this came out in 2020 and we have had no problems with it, we have 75k miles and it states that not just any tech they have can do it. Just thinking if it has not failed yet it probably wont...
  8. gonegreener
    Arizona
    2015 Prius v wagon
    Has there been any issues with a vehicle after they reprogram? Anyone still not get this done? Just thinking if not broken don't fix it mentality..
  9. gonegreener
    Arizona
    2015 Prius v wagon
    Ok, I took it in this morning and picked up the prius v just now after they said it was ready. they reprogramed the PWR MgMT ECU
    Brian1954 and Air_Boss like this.
  10. rjparker
    9,485
    5,808
    Texas Hill Country
    Plenty of fails after reprogramming.
    douglasjre and Tim Jones like this.
  11. Air_Boss
    4,132
    1,151
    New Yawk
    At the time, circa 2018, that was my concern. Whatever heat cycle damage may have been done would not be rectified by a firmware reflash. And performance could be programmatically degraded by the reflash. Thankfully, no downside to report.
  12. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    My Failed after reprogramming at 167,000.......... 1100 miles from home.
    It will fail.....
  13. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    It can fail at any time....... especially after 100,000miles. They could possible jack with you if it hasn't been updated...when it fails...........
    Your thinking on this is flawed.................................
  14. ChapmanF
    17,178
    Since the quoted post (#7), the poster has had (#9) the firmware update.
    If the inverter fails and they try to jack with you, just point them at the right customer service program docs, which clearly cover the failure for 20 years and unlimited mileage.
    So, that means after a failure, you can get the car fixed. It doesn't change that it sucks to have the car fail while you're driving it. Getting it fixed for free comes after the sucky part.
    The idea behind the later power management control ECU reflash was to make the sucky part suck less. The intent is for the car to respond to the failure by going into a limp mode and you can still sort of drive your way out of traffic. Even without that reflash, that's what'll usually happen, but without the reflash, there's still a chance it responds to the failure by shutting the hybrid system OFF. In traffic, that sucks more.
    Brabus82 likes this.
  15. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    Had the firmware update at about 250k and the failure at 270k. They replaced the inverter converter assembly free of charge
  16. Brabus82
    Brabus82 Junior Member
    Taylors, SC
    2015 Prius v wagon
    I haven't updated mine for the same reason. My 2015 has 201,000 miles on it and I'm afraid to change something that has worked well for a long time. If they cover it unlimited miles, maybe it's worth doing.
  17. ChapmanF
    17,178
    The inverter in your 2015 at this moment is 201,000 miles closer to failing than it was when it rolled off the line. No update installed at this late date will undo any of that past usage.
    There were two updates to the firmware. The update that came with recall F0R was meant to fix the conditions tending to crystallize the solder, and the later update with recall J0V is to avoid having the hybrid system shut completely off if/when the inverter does fail.
    It's possible you could have had one done and not the other. For example, if the F0R update was done 100,000 miles ago, then your inverter in theory might be only 101,000 miles closer to failing than it was at the factory.
    Still, the later update is worthwhile because it affects what can happen if/when the inverter does fail. It is nice knowing Toyota will replace it for free if it fails, but you could still be on the road when it happens and have to deal with that. It is better to have the car go into limp mode so you can get out of traffic. But if the J0V update hasn't been done, there's a chance the hybrid system just suddenly turns off, and that could suck.
    Brabus82 and Air_Boss like this.
  18. douglasjre
    2,085
    698
    Null, NL
    Does anyone have pics of the IPM failed part and an analysis of why
  19. ChapmanF
    17,178
    The analysis of why is in the Defect Information Report that Toyota supplied to NHTSA and can be downloaded from there. I don't remember that it has pics though.
    The TSBs that go with the inverter-replacement customer service programs describe a few different scenarios for what actually happens at the moment the failure goes from incipient to complete. It'd make sense that there are lots of variables, such as just how much power is being handled at the moment it lets go, and even which phase is 'it'. Sometimes just the IPM needs replaced, sometimes it takes the MG ECU with it, sometimes the Hall current sensor assembly too. Sometimes it damages the aluminum case; you get a whole new shiny inverter assembly when that happens.
