Weak 12 volt causing P3030
Discussion in 'Gen 2 Prius Main Forum' started by Sharnold, Sep 27, 2019.
  1. Sharnold
    Sharnold Active Member
    379
    119
    Alabama
    Got a good one for you car came in with P3030 cleaned all the bus bars replaced 4 cells reinstalled reconditioned HV battery pulled this code on techstream the other day. Started to pull the codes to erase got a P0A80 then dash goes black no start condition the 12volt battery has 7volts and I closed the hatch before I started ...... it's been a great afternoon. Tomorrow I'll be crawling to the back of the car to jump the battery to open the hatch just so I can replace the 12volt
    #1 Sharnold, Sep 27, 2019
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,231
    5,934
    Columbia, SC
    Sharnold…..
    rough day....you must be tired.
    sometimes we forget, this is the perfect time to use the under hood jump point....
    Skibob, jerrymildred and Sharnold like this.
  3. Sharnold
    379
    119
    Alabama
    Working both jobs yesterday I was pretty tired. I wasnt thinking very clearly I think it was mostly the.....why did I close the hatch that was on my mind.
  4. Sharnold
    379
    119
    Alabama
    Also I never plugged the fan back in so I'm guessing there may be this issue with the other code
  5. ChapmanF
    15,653
    Good thought. If so, you might consider changing the thread title.
    Otherwise your post will forever be getting cited as another piece of evidence by the "weak 12 volt causes everything" contingent.
    strawbrad, Sharnold and jerrymildred like this.
  6. Sharnold
    379
    119
    Alabama
    It's not giving me the option of changing the title or editing it
  7. ChapmanF
    15,653
    You can use the 'report' link and ask for a change.
  8. strawbrad
    953
    999
    The P3030 code points to bad voltage sensing wires or a corroded voltage sensing wire plug at the battery ECU. Did you look at live battery block voltages with Techstream or another app before taking the battery apart? Did you remove and inspect the plug at the battery ECU?
    What are you using to read codes? You're doing enough Prius work that you really should be using Techstream.
  9. Sharnold
    379
    119
    Alabama
    I cleaned the bus bars inspected the wiring checked all connections and replaced 4 cells it was only a faulty auxiliary battery the car is repaired and out the shop now. The owner has already picked it up. I am already running techstream. All it was was the auxiliary battery and the lack of me plugging the fan back in after cleaning...... lesson pay attention and dont work while exhausted
  10. RoadworrierXL-5
    RoadworrierXL-5 Junior Member
    california
    Note for the future: you can pop open the back hatch manually by crawling back there and flipping a small black latch next to the main one. Prius can be serviced sans power in many situations. Ive rebuilt my hybrid battery without having the 12VDC battery connected at all.
  11. TMR-JWAP
    6,231
    5,934
    Columbia, SC
    Are you sure that is accessible in a Gen 2 when the hatch is shut? I seem to remember that little lever being under all the plastic trim, which seemed kind of dumb at the time. How do you get the trim out of the way if the hatch is closed? Or do you have to pull up the floor plate and the plastic tray to get to it?
  12. ChapmanF
    15,653
    You lift the floor plate and just pop the small cover out of the plastic tray so you can reach through to the release lever.
  13. Sharnold
    379
    119
    Alabama
    Yes that little guy makes popping the hatch easier unless you've put together the whole trunk assembly. It's much easier to jump the block and pop the deck lid from the outside
    Skibob likes this.
