Weak cabin air flow when on heat.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Dec 2, 2022.
  1. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    on defrost no issue blows fine on low or bottom seems fine just on vents on heat is weak. notice it got worse when its 36F outside. seems like pressure from being on the freeway was only thing pushing air in the cabin.
    52,356
    could be stuck damper door
  3. johnnychimpo
    514
    112
    Monterey
    how do I fix that like the actuator.
    52,356
    Some of the dampers you have to dismantle the whole dash
