Weak Homelink Signal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rew9, Nov 1, 2010.
  1. rew9
    rew9 Junior Member
    Waldport, OR
    I have to almost into the Garage Door to get it to open or close when backing out is anyone experiencing this same problem, if so what was the remedy thanks rayw
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Mine works from more than a block away, just have to hold down the button a little longer.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    No issues for me, but I had a similar issue with a previous car/home. To fix it, I made a U shape with a 18" piece of very thick wire (stripped of the insulation) and attached it to the garage door opener's antenna. Went from needing to be in driveway, to half a block range.
  4. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I'm also good for a few hundred feet. H
