Weak Radio reception in the rain?
Discussion in 'Prius v Audio and Electronics' started by Capecodbeachfront, Feb 21, 2014.
  1. Capecodbeachfront
    Capecodbeachfront Junior Member
    55
    2013 Prius v wagon
    Up until now I have been quite satisfied with the basic radio in my 2013 Prius v Two. Actually figured out the USB port as well as the Random files and folders settings. BUT....
    Today we have had an all day winter rain. I immediately noticed 2 things. First the roof has almost no sound insulation! Rain on the roof was LOUD! Then I discovered some of the radio stations I had been listening to for over a week were now nearly lost. Reception was probably a tenth of what it was in dry weather. Should I blame the weather? Could there be a problem with water interfering with the external antenna? Even stations that were very close and should have had a strong signal would at times have interference. Is this common with Prius v's? Is there an antenna upgrade?
    One other question... When I am in Trip display.... showing the MPG bars what are the tiny symbols that sometimes appear at the bottom of the bars? Appears to be symbols for Regen braking. How should I interpret them? Good thing? Bad thing? thanks.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,844
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Common in all Prii. I could not use the radio today in my 2004 except on the local town station. Not great listening.
    JeffD
