WeatherTech Side Window Deflector installation help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mikenancy1, Jun 8, 2013.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    Trying to put the side window deflectors on the car. Followed the instructions, but found the front windows squeak at the top, where the window hits the deflector. It's not a pretty sound. The deflectors seem to be seeded correctly. Any advice?
  2. Johnny C
    Johnny C Member
    162
    16
    Boston
    Have you tried opening completely and closing completely 10 times after installation? What was the temperature when you performed the installation?
  3. mikenancy1
    105
    Geneva, IL
    Yes, I did those things. The temp was in the high 60's.
  4. Johnny C
    Johnny C Member
    162
    16
    Boston
    I think the noise will go away once it sits in warmer weather.
    ou812 likes this.
  5. mikenancy1
    105
    Geneva, IL
    Do you have them, and if so, did you experience the same thing when you first installed them?
  6. nedear88
    nedear88 My 1st Prius.
    245
    140
    San Bruno, California
    Yeah, I have them...after 1 replacement set, it still squeak makes strange rattle sound on the passenger side, also the "Auto" window up function always protect and windows never close fully unless by close it manually. At the end...last month, I removed it. I may sell them used if anyone wants it. It will be reasonable $$.
  7. ou812
    ou812 Junior Member
    40
    They work fine on my 2010, no squeaking or window problems.
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    Wait until winter, when it's cold the window won't close, the sucker's are in the rails and the window senses pressure, takes several attempts to close when cold, not to mention the noise they make rattling around when the windows are partially open(at speed), and if the front's are being a challenge, the rears are going to be ;) comforting
  9. Johnny C
    Johnny C Member
    162
    16
    Boston
    I have something similar to WT but cheaper. They are also in-channel. I have not installed them yet but I am a bit concerned about the auto-close functionality affected if I install these. Perhaps, the double tape version is more suitable? I know the JDM Toyota version is installed using tape, not in-channel design.
  10. WE0H
    WE0H Senior Member
    3,247
    527
    Why use them at all?
    Mike :)
    Mobile on my SGH-i717
  11. ou812
    ou812 Junior Member
    40
    because it gets hotter than hick it my Blue car and being able to leave the windows open helps alot, I've had these in my car since I purchased it new and have had no problems with any of the windows at all.
    WE0H likes this.
  12. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I had them on my last car, the in-channel ones look nicer but not good for the window motors. I am going to try the stick on ones on the Prius Sun is in my face..........:censored:
