Weber State University does P610 deep dive
Discussion in 'Prime Technical Discussion' started by bwilson4web, Jun 15, 2017.
  1. bwilson4web
    16,369
    Meg&Bear, Matthew007b, RandyW and 7 others like this.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Thanks for sharing.
    Although prof. Kelly stated that the PSD (Power Split Device) was not changed at all since P111 (1st gen) I did find one change: in P610 (4th gen and Prime) the number of planets has been reduced from 4 to 3 ! Since with 3 planets, the torque carrying capacity of each tooth in the PSD (sun, planet or ring) is 1.333 (4/3) times the capacity when using 4, IMO it may indicate increased confidence by Toyota in the PSD service longevity.
    #2 giora, Jun 16, 2017
    farmecologist and bwilson4web like this.
    52,393
    no idea what i'm looking at, but fascinating nonetheless.
    would love to see him compare prius v ionic.
    Tips likes this.
  4. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    Thanks for sharing this. I find it very interesting. Layers of clever engineering.
    Simplicity through complexity.
  5. bwilson4web
    16,369
    It took me a long time to finally understand the dynamics of the Gen-1 transmission. I'd like to see is an equivalent, dynamics analysis of the transmission . . . which would probably be of equal length. Understand these are my questions, not a criticism:
    • 'heretical mode' - when MG2 works as a generator to power MG1 to provide counter torque occurs about 25 mph in the Gen-1. Does this same speed threshold occur with the P610?
    • I have to review it but towards the end he discussed (if I understood it) that 'MG1 is held stationary and the engine rpm more closely follows the vehicle speed.' - this suggested some speculations over the past decade that a mechanical brake on MG1 might significantly improve transmission efficiency by avoiding the electrical load path. BUT I could have misunderstood his discussion and sad to say in this video he didn't have dynamic metrics from a running Prius Prime.
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Wow. Thanks Bob.
    Someone really needs to get him a cameraman. I can't believe he's talking, taking it apart, and working the camera all at the same time.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    A magnet is back to pick up magnetic metal in ATF, last seen in Gen 1.
    This has external ATF plumbing, so those of you wanting an ATF filter can add one.
    It features no internal coolant, just an external heat exchanger with ATF.
    He clearly shows drip tubes cooling M/G1 and M/G2 with ATF.
  8. bwilson4web
    16,369
    FYI, Professor Kelly checks the comments of the YouTube version. I recommend leaving a 'Thank you'.
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Do not know about the Gen 2 but Gen 3 (P410) does have a magnet at the bottom.
  10. bwilson4web
    16,369
    About transmission and engine oil pan magnets, they should be in the drain bolt. That way when the oil is changed, the debris on the magnet can be inspected and removed.
    Beachr5 and Meg&Bear like this.
  11. hill
    8,925
    The benefit of working near a mag-particle inspection room (ever since the early 1980's) - it's easy to drop off a couple drain plugs so they can get magnetized.
  12. Trollbait
    12,687
    Many transmissions simply don't have a drain.
  13. hill
    8,925
    A manufacturer's fail, is an opportunity for your d.i.y. skills to shine ....
  14. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
    Wow great video. I'm always fascinated by these.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Another one for my collection. These transaxles are amazing.
  16. Trollbait
    12,687
    Except in the case that most automatics have a filter to replace, and the pan needs to be dropped either way.
  17. KrPtNk
    323
    283
    Pacific Northwest
    I wonder what he does with with the car after he reassembles the transmission. I think he said he has to reinstall it when he has finished his exploration.
    I assume the car Is kept as a teaching resource at the college. Is there any way it could be sold? Wouldn't the warranty be voided.
  18. hill
    8,925
    It might just be that some these vehicles' parts weren't up to spec, so they're strictly used as demo/teaching models.
    Wow, thinking of that stater, & how much of that unit is now copper rods formed into shape & welded into position instead of windings ... what a trip.
    #18 hill, Jun 20, 2017
  19. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Meg&Bear likes this.
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The magnet area is considerably larger than the drain bolt cross sectional area, so, may be more effective for "ATF for life".
    Trollbait likes this.
