weight on front vs rear axle
Discussion in 'Gen 2 Prius Technical Discussion' started by olderguy, Sep 21, 2008.
  1. olderguy
    olderguy New Member
    chicago
    Anybody know how much weight is on the front and rear axle of an 08 Prius?
    Does the ratio match the ratio of the recommended tire pressures?
    thanks
  2. ChapmanF
    15,057
    You could start by looking at the Gross Axle Weight Ratings (GAWR) on the sticker on the driver's door pillar. Those are for when the car is fully loaded with the maximum allowable cargo. When it's unloaded it is probably more front-heavy than that, because the cargo weight you have control over is more toward the rear, and the weight up front is dominated by the drivetrain.
    The relationship between tire pressure and load capacity is more complicated than I thought; I tried to learn some about it here and one reference I found was a Tire Replacement Manual that had some load tables in an appendix.
    -Chap
  3. patsparks
    10,664
    567
    Adelaide South Australia
    I weigh vehicles as part of my job, I'll try to remember to weigh my car on the way home tonight. It is a 2004 but the weights are very near the same across model years I suspect.
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    If Pat doesn't come up with the info, go to any commercial truck scale, or a gravel pit with a scale. You can weigh each axle any way you wish.
    Icarus
  5. jackblack99
    jackblack99 New Member
    youve got yours set heavy.. mine is a little more rear heavy.
  6. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
  7. patsparks
    10,664
    567
    780kg front and 540kg rear with 200km (8 to 12 litres) of petrol and about 10 to 15kg of stuff in the back.
    Total 1320kg
    I have a 2004 Australian base model.
  8. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Japanese 2004 base model, 1250kg
    Front: 750kg, Rear: 500kg
    Japanese 2004 G Turing JBL model, 1300kg
    Front: 770kg, Rear: 530kg
    Ken@Japan
  9. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    wow. i'm amazed that i learn something everyday here at priuschat. THANKS!
    pat - you're an awesome HD of info. cheers!
  10. patsparks
    10,664
    567
    As I said, I weigh vehicles for a living, well a good part of it anyway, and what I didn't say is one of our weighbridges is 5 minutes from my home.
    Ken, where are your weights from?
  11. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    They are from Toyota's specification sheet.
    Ken@Japan
  12. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    That's darned close to the 60/40% front-to-rear weight distribution mentioned previously. And since the fuel tank under the front seats has to be close to the CG, it probably doesn't change much with fuel load. However, with passengers in the rear seats and lots of cargo load, the CG will shift rearwards enough to affect handling I would expect.
    Has anyone noticed this to any degree?
    Ron.
  13. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    The fuel tank under the rear seats.
    Ken@Japan
  14. ronhowell
    681
    32
    Cypress, CA.
    Thanks Ken. I stand corrected. I had read somewhere that the tank was under the front seats and hadn't really checked to make sure it was true.
