Weird 3-bars became flash
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Dec 18, 2014.
  1. bwilson4web
    16,010
    So yesterday I was driving home and had 3-bars remaining with ~330 miles on the tripmeter. I usually expect ~50 miles per bar and then another 50 on flash, so it looked like another 500 mile tank. Then that night, my wife wanted something and by the time I got to the traffic light, 'bing' and it was suddenly on flash. Wth?
    I filled up this morning and only got 8.9 gallons, not the expected 10-11 gallons. So I suspect a bump or something else triggered a false, low-tank reading. This triggered the "flash" and unexpected, low fuel indication.
    This is the most extreme mismatch between the indicated and fill-up quantity I've ever seen. Granted, the fuel gauge is more a 'guess gauge', it has got me rethinking about a different approach: calculating the fuel consumed from the engine metrics instead of the floating 'float.'
    usnavystgc likes this.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    I use scangauge to check for exact fuel in the tank on my 2010. It only measures from 11.4 gallons to .7 gallons but in .1 increments. Turns, accelerations and braking changes the value gasoline in the tank as much as 1.5 gallons. Once near empty both gas gauge and scangauge become inaccurate. I drive additional 75 miles at the first sight of blinking fuel warning before fueling up.
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    I hate the one-beep and one-bar-flash low fuel warning. I haven't missed it so far, but one day I expect I will, and find I'll myself on the road without any gas.
