Weird AC and Headlight issue
Discussion in 'Gen 2 Prius Main Forum' started by Dr_DLH, Aug 22, 2019.
  1. Dr_DLH
    Dr_DLH Member
    106
    So we have a 2005 Prius and I searched for the same issue on this forum and nothing could be found.
    The right side headlight is off during the day, at night its on. I am getting code 21 and 23 from the car. I see that 21 is the light sensor.. ok so I had covered the light sensor to see if the light came on.. It did and the ac came on as well. but then later it went off... ugh.. But strange at night the head light is on and the AC works.. This is very confusing. I dont know whats going on here as the wiring is all stock and we havent had any problems with this car besides the inverter pump and passenger air bag light.
    Has anyone experienced this? We had the AC serviced and the mechanic is stumped. All is good as far as pressure and freon.
    #1 Dr_DLH, Aug 22, 2019
  2. ChapmanF
    17,336
    The two-digit codes you're getting from the HVAC system are only for the HVAC system. They won't illuminate your headlight issue any. That might just take some old-fashioned multimeter work.
  3. Dr_DLH
    Dr_DLH Member
    106
    I really am not concerned at the moment about the headlight but more of the AC as the heat outside is over 95 and over 105 starting tomorrow for over a week... ugh
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    The only way I could see a headlight and the AC having anything in common would be for them to share a wire run or a power source. How that could be affected by light or temperature, I'm not sure.. I've learned that nothing is impossible. This could be interesting.
    Do you have HID or halogen headlights? If you have fog lights, the car also has HID headlights. No fog lights then the car has halogen style.
    Does the AC work at all during the day? Perhaps works ok when the car is cool (or first started for the day), but then drops out when the engine is hot?
  5. Dr_DLH
    Dr_DLH Member
    106
    They are the HID expensive headlights with the ballast as I had to change the left one a few years back. Yes it has fog lights, yes it’s weird how this is working.
    My daughter drove the car today and this is what she said.
    “Now it’s cold. Been having it run the whole time
    Goes back and forth. Every five minutes it switches to a swamp cooler. I just timed it”
  6. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    I have seen intermittent AC operation be caused by failure of the inverter cooling pump. Failure (or weakening in some cases) of this pump loses (or lowers) coolant flow to the inverter. This causes the inverter to run at higher than normal temperature. The AC compressor is essentially powered from the inverter, so the car turns off the AC to reduce heat load at the inverter. It may be worth checking out the inverter cooling system, as if this is happening, it rarely causes any codes or faults until the pump totally fails or the inverter totally overheats. This situation has led to many people throwing a lot of money at the AC system when the real problem is the inverter cooling water pump or coolant loop. This pump is located directly behind the driverside headlight.
  7. Dr_DLH
    Dr_DLH Member
    106
    Forgot to mention that I did replace the inverted pump a few weeks ago because all the lights on the dash came on and engine code P0A93.
    But the ac issue has been going on for a month or so..
  8. Dr_DLH
    Dr_DLH Member
    106
    My brother just mentioned it maybe the pressure switch and/or the shrader valve.. may just replace both.. headlight maybe a coincidence and the ballast is going out...
  9. ChapmanF
    17,336
    Suggestion: fill a small bucket with water. Put your tools in it. Put the bucket in the freezer, and let it freeze solid so you won't be tempted to grab the tools and start taking things apart.
    While that's happening, just curl up with the 15 pages of code B1423 troubleshooting steps in the repair manual (more info), and read through them, getting familiar with the sequence of things to test to figure out what's going on. Then thaw out the tools and have at it.
    Skibob likes this.
  10. Dr_DLH
    Dr_DLH Member
    106
    That is not helpful?
    That doesnt seem helpful? I all ready have the Toyota Repair manual and it doesn't have the 23 code in it as I stated in this post. Plus we I have gone through the steps to find out whats going on as this is not normal behavior for an AC system. I am going to replace the easy parts and go from there as suggested.
  11. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Chap has a point. Somehow I missed the codes you mentioned earlier. I tend to just skip over any 2 digit code info. But a 1423 kind of points you in a good direction to go....assuming it's a legit code.
    I'm pretty sure the 1423 code pretty much says pressure too high or pressure too low, so this:
    We had the AC serviced and the mechanic is stumped. All is good as far as pressure and Freon
    may not be true
    Has anyone been adding to it? Are all components clean? Have you tried it in both recirc and non-recirc modes? varying fan speed? Is air always blowing out of the vents, but not always cool?
  12. Dr_DLH
    Dr_DLH Member
    106
    The code I received was 23 not 1423.. but to answer your questions.
    Yes all components are clean and no leaks or oil anywhere.
    Radiator fan is on
    Blower fan is on
    Both recirc and non yes
    Air blows cold then swamp cooler cool,
    Last night my daughter drove it out of town 1.5hours and it cooled the whole time.
    What’s really weird is the high temp side pipe should be hot to touch and it was not. But cooling when we had it serviced. The sucked out all the Freon, places a vacuum to the system for 1 hour. Shown no leaks. Placed the Freon back in and tested it working. 20min after leaving it started the swamp cooler and ac every 5min.
    #12 Dr_DLH, Aug 23, 2019
  13. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    23=1423=B1423
    B1423 is the true code. That 2 digit stuff is just abbreviations
    Just like 21 is B1421
    Are you confident the inverter cooling water system is good to go? Do you have any apps (similar to hybrid assistant) and a Bluetooth OBD device you could use to monitor inverter temps while driving?
    Raytheeagle likes this.
  14. ChapmanF
    17,336
    If it helps any, the two-digit codes you can retrieve from the HVAC in the corner of the MFD are versions of five-character actual DTCs. The 23 corresponds to the trouble code B1423, which you can find in the manual. Sorry if that wasn't clear.
    Note that not all of the ECUs have such a simple correspondence between their shortened codes and DTCs. For the HVAC you can more or less take your two-digit MFD code and stick B14 in front. That is not always the case for, say, brake or airbag blink codes, which pretty much have to be looked up. They'll appear in the manual following the corresponding DTC, separated by a slash.
    Even though B1423 may have a one liner "fortune cookie" that says something like pressure high or low, the fortune cookies all have to be interpreted using the question "why would the ECU think that?" and the answer to the question can always include faulty sensors, wiring, electrical connections, etc., as well as the possibility that the sensor reading is right.
    The workup pages in the manual are intended as an efficient way to make the necessary tests to sort all those possibilities out.
    jinx
  15. Dr_DLH
    Dr_DLH Member
    106
    Thank you, I will be reading up on that and get back to you all. Thanks a bunch everyone!!
  16. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    The swamp cooler thing is just the compressor turning off and the moisture on the evaporator burning off. There is an AC section in techstream it shows temperature, humidity and other things I can’t remember. I would get and use techstream before you wrench on anything. Is there a puddle of water under the car when you run the AC?
  17. Dr_DLH
    Dr_DLH Member
    106
    Yes I have access to a laptop with cable and tech stream.
    For some reason the dealer told me the AC pressure switch is not available anymore??
    I will check the car more this weekend as my daughter drives it now.
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Low pressure makes sense. If there's not enough coolant, the evaporator ices up and stops blowing cold and blows sort of cool and humid. Once the ice melts, it blows cold again till that coldness freezes the condensation on the evaporator again. And round and round you go.
  19. Dr_DLH
    Dr_DLH Member
    106
    Usually vehicles have a high and low pressure switch but I can’t locate the low one on this particular vehicle.
  20. ChapmanF
    17,336
    Somebody should check me in the manual, but I think in a Gen 3 what you're seeing may actually be a pressure transducer.
    I think in your Techstream data list you can actually view pressure, not just a low or a high switch.
    Design in a transducer, you've as good as got both switches.
