Weird air noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jessie1188, Nov 24, 2024.
  1. Jessie1188
    Jessie1188 New Member
    Tennessee
    Hello all, I have a 2013 Prius hybrid. My rear pads and rotors were making a weird dragging noise. I ruled out everything else and decided to replace the pads and rotors. This car has 203k miles on it. I replaced the pads and rotors on all four wheels and during the process everything went fine except for the right rear caliper piston wouldn’t retract and I had to replace it. I pinched off the brake hose before it meets the banjo and everything seemed to go smooth. I did not bleed the brakes. My brake pedal felt normal after this job, and I went on a couple test drives and it seemed like before but more reactive. As in the brakes feel great. I do not believe I introduced air into the system, but I am not ruling out that possibility. However, now when I push the brake pedal with the car on or off there is this loud noise that sounds like air is dumping out of the car. I couldn’t find a single person talking about this. Is this normal? Is it just the car getting used to the brakes? If anyone could give me insight on this I would greatly appreciate it. Thanks in advance.
    51,027
    how is the brake fluid level?
    any chance of recording the sound? any idea where it is located?
  3. ASRDogman
    ASRDogman Senior Member
    7,116
    3,713
    You introduced air into the system when you changed the calipers.
    You should have bleed them. It would have been quick and easy.
    You need to bleed the brakes. Just make sure the resevior is kepted topped off.
    Brian1954 likes this.
  4. Jessie1188
    Tennessee
    UPDATE: I ended up bleeding the brakes after those two short test drives, and guess what??? Problem solved. I’m just going to leave this here incase anyone else comes across this issue. ALSO, just wanted to say if you are having issues with the chicken dance and getting into invalid mode, add a little more fluid to your reservoir. I don’t know the why at this time, but it was the only thing that changed and worked after several attempts.
    Brian1954 and ASRDogman like this.
  5. Jessie1188
    Tennessee
    Thank you for your answer, I do believe you are correct. I did bleed them and problem solved. Thank you SO much for your reply.
  6. ASRDogman
    7,116
    3,713
    It's just a coincidence....
    Glad you got it working correctly.
    ALSO, just wanted to say if you are having issues with the chicken dance and getting into invalid mode, add a little more fluid to your reservoir. I don’t know the why at this time, but it was the only thing that changed and worked after several attempts.[/QUOTE]
  7. Jessie1188
    Tennessee
    [/QUOTE]
    you think it’s a coincidence that I added fluid and then it finally worked? I don’t know, man. Maybe you’re right. Let me ask you this, do you know of any reason why the car won’t go into invalid mode, aside from someone doing “the dance” incorrectly, and the car not recognizing the ebrake/park/neutral being engaged? I’m really curious. I did have a thought that maybe there is some kind of “sensor” or something that reads the fluid level. I don’t know. I sure am happy I got it resolved though.
  8. ASRDogman
    7,116
    3,713
    What does it matter? Just be happy it worked.
