Weird Beeps When Driving
Discussion in 'Gen 2 Prius Main Forum' started by gordonb, Feb 9, 2011.
  1. gordonb
    gordonb New Member
    Seattle
    I have a 2005 prius with navigation, smart key, hid lights; not sure what the package is called. Today while driving I heard two short beeps that I have never heard before. At first, I thought it was my Ipod or cell phone. I turned off the radio, turned off the climate control and drove until I heard it again. Two barely audible beeps; the second one about 1 second behind the first. I put the car into the diagnosis mode via the nav screen, ran a test and all checked out ok with the exception of the audio h/u has a yellow box with the words "chek" in it. When I press the yellow box it doesn't show any error codes. I'm not too worried about it but it just started happening today. Does anyone know what this means or if there is a problem? Any advice would be greatly appreciated.
  2. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    I've heard beeps when my smartkey drops out. Probably the signal gets blocked by the other keys in my pocket. Usually I'll see the red "key" in the dash lights when that happens.
    It usually goes away in a few seconds.
    49,492
    could be a maintenance check programmed into the nav screen. go into maintenance and look around.
  4. BrettS
    BrettS Active Member
    290
    136
    Orlando
    I believe the traction control system beeps when it engages... Is it possible that's what it was?
  5. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Did you check the gas gauge? It beeps when it gets low...
  6. Patrick Wong
    18,200
    6,474
    I suggest that you replace the fob battery.
  7. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    This is what I was going to suggest as well
    This should help:
    2004-9 Prius Keyfob Battery Change
